This is one of the gain stages of the clean channel
of a guitar preamp I'm building. It is driven by a unity gain buffer and following it is a tonestack and then another gain stage. More important than keeping the 'hi-fi-ness' of the amp is to suppress all kinds of noise as much as possible since the working environment is usually not the best (long cables, bad grounding, tons of other equipment inducing noise on powerlines and into signal path) I'm just wondering if there are any errors in the schematic or anything that can be improved. |
#2 | |
The upper 10 Ohms resistor must be conncted between the positif rail and the point of connection of the upper capacitors and the + pin of the op amp. In the negatif side ,the resistor is correct but must be connected to the - rail and not the ground . Cheers PS: this will permit operation!
Jorge |
#3 | |
Account Disabled
it might be for single rail application. With one slight change, it will work. |
#4 | |
Yes it can...but in this case the input voltage divider is missing!! And the capacitors and the resistor that are in the ground "rail " are not needed!
Jorge |
#5 |
I haven't yet drawn the virtual ground driver
circuit. I figured a BUF634 would be perfect for the job. Pretty common I guess. So if VCC would be 30V then VGND is 15V and GND 0V. I read an article* about decoupling and grounding posted in the chip amps forum, but it left me with more questions. (*An IC Amplifier User's Guide to Decoupling, Grounding and Making Things Go Right for a Change - Paul Brokaw) Yes, I am uncertain about the placement of the 10 Ohm resistors and possibly the decoupling should be done directly from the positive pin to the negative pin. Also most examples assumes double rail operation while single rail operation is rarely touched. So if I understand you guys the upper 10 Ohm resistor is in the wrong place, but the rest is pretty much okay. I have a quite similar circuit up on my bread board. Some values are different and the pot is missing, but the rest is pretty much the same. Tinkering with the decoupling caps gives somewhat inconclusive results as does moving the 2.2uF connection from VGND to GND, which pretty much suprised me since I thought this would put the op outside the linear region (=distortion). As for the voltage divider the VGND is set by a BUF634. It will keep VGND stable at half the supply voltage. Measuring between the positive input and ground shows ~15V at 30V supply voltage... It should work pretty well... |
#6 |
Account Disabled
as far as decoupling is concerned, the caps can pretty much be tied to anything, from Vcc to Vgnd to Gnd, as they all are "gound" for a/c signals.
the decoupling resistors should really be between the power supply (Vcc or Vgnd) and the decoupling caps. But in this case, the time constant is simply too small for them to have any real effect so I would take them out. another thing, I would use a pot to alter the gain of the circuit. in your case, the gain goes from 1/2 to 2x. a lot of opamps aren't stable at close to unity gain. I would have put the pot upfront, as an attenuator to the non-inverting terminal. |
#7 | |||
a bit of a trail-and-error approach. Quote:
that no rf noise wouldn't find its way to the output of the opamp. When having long cables it is not uncommon hearing long wave radio broadcasts. Maybe just the caps are more than enough? Quote:
was very much influenced by other guitar fx rather than hi-fi equipment. I know that altering the gain this way will also alter the frequency response somewhat. I'll have a go putting the pot in front since I have the circuit up on the breadboard anyway. As for the selection of opamps I have quite a few to chose from in my box-o- many-things, OPA134, NE5532, TS922, even JRC4558, and more. If none of these works with the 1.5 kOhm resistor it will be replaced by a larger value. One last question. The gain of this stage is calculated according to G = 1+R1/R2, thus min gain would be G = 1+18/(50+1.5) ~= 1.35, and max gain G = 1+18/1.5 = 13 ( 2.6 dB to 22.3 dB ). Or??? Is it just G = R1/R2? It's G = 1+R1/R2 for non-inverting stages, right? Thanx for all the feedback. When I'm grown up I'll give it back. |
#8 | |
Yes !...you are right!! with your set up the minimal gain will be 1,35 and the maximal gain 13. You got it! About op amp choice...i think guitar capsules have high impedance output...if that is the case then you must use a Fet input stage op amp for lower noise and not load the capsule.
Jorge |
#9 | |
When you refer to capsules, I am not really sure what you mean. Guitar pickup (the microphone mounted on the guitar), a guitar effect unit (small box on the floor with some controlling knobs) or rack effect unit (19" rack mounted unit usually with LED display and tons of confusing possibilities). As for guitar pickups there are passive ones and active ones. The active ones have an opamp stage built-in and you'll have to have a battery compartment in the guitar. The passive ones are in essence just a copper coil with an inducance in the range 2 to 8 henry and DC resistance of about 5kOhm to 15kOhm. Good advice. Using a FET input stage op is avery good idea I think. The schematics posted shows the second stage. The first stage is a unity gain buffer, however I have yet to choose an op for it. Out of the ones I have available with FET input the OPA134 is the one with the best spec. |
#10 | |
If they are high impedance a fet op amp is better...if they have allready a incorporated buffer and the output impedance is lower...then the op amp requeriments are less stringent!
Jorge |
| Does USB->I2S make sense ? | percy | Digital Line Level | 20 | 24th March 2009 01:23 AM |
| Linear voltage regulator: how to make good use of "sense" and "ground sense"? | NeoY2k | Analog Line Level | 7 | 6th September 2008 11:35 PM |
| TL, does this now make sense? | Madmike2 | Multi-Way | 2 | 8th May 2005 02:39 PM |
| Does this make sense ? | 00940 | Solid State | 7 | 27th March 2004 09:29 PM |
| Does this make sense? | Illusus | Chip Amps | 11 | 25th September 2003 01:59 PM |
| Page generated in 0.16732 seconds (76.16% PHP - 23.84% MySQL) with 11 queries |
