I've searched around the forums, but so far haven't come across what I'm looking for. I'm getting ready to build an MTM speaker where the mids are 6 ohms nominal. If I put them in series, I don't get the increased sensitivity I want, but if I put them in parallel I get a load that looks like 2.5-3 ohms through the midrange.
SO, has anyone put together an amplifier PCB or kit that will deal with a 2-ohm load? I'd be looking for something that could generate 300WPC into 2 ohms, roughly. Thanks in advance for any advice you might have. Paul Pickard |
#2 |
It sounds like what you should really be focusing on is addressing impedance compensation in your crossover design and not a 2 ohm capable amp.
However, if you are set in your ways, you can search on "BPA200" and "bridgeclone" to see what you like in the 2 ohm world.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
I'm fairly new at this with only a couple of basic designs under my belt, but what can you do in the passband besides add series resistance? Certainly that raises the impedance, but it also lowers the sensitivity.
Paul |
#4 |
Yes, put the speakers in parallel and add a 1 ohm 25 or 50 watt resistor in series. This will bring them up to 4 ohms. You do lose about 1 db in sensitivity but you can't have everything.
Dan Fraser |
#6 |
If you have a 3 ohm load and you put 1 ohm in series with it, you are into tube range damping factor. Depending on the crossover you could have significant anomolies from the predicted response. I believe Rod Elliot's article on damping addresses this.
#7 |
why not "tri-amp"?
separate amps for each driver; the M amps could share power supply, the output devices/heatsinking will cost nearly the same with 2 amp approach, the only "extra" cost over a lo-Z amp is small signal/dirver stage stuf and a superior performing low power T amp and the active crossover |
#8 |
The advice about series resistance is completely incorrect.
Its as lot easier in terms of output devices to build a 300W/8ohm amplifier than a 300W/2 ohm amplifier, personally I can't see the point of your concern with voltage sensitivity, efficiency of the series or parallel connected drivers is identical. (Any difference in speaker voltage sensistivity in a multi channel set up can be addressed by adjusting the amplifier gains.) sreten.
#9 |
I'm hoping my famously bad memory doesn't get me into trouble yet again
I think ribbon speakers are low impedance (right?) so this Borbely Audio amp may be worth investigating On the other hand, "ribbon" is probably just a name for the amp model. mlloyd1 |
#10 | |
In my MTM I have 2 mids that are 92db/2.83V/1m, and a tweeter that is 96db/2.83V/1m. Ignoring baffle step (for the moment), if I want a 96db/2.83V/1m MTM, I need to put these 6 ohm mids in parallel. Before anybody says it, I'm already planning an active system (which is why I can ignore the baffle step for the MTM): the MTM from 300hz to 20kHz, Lambda TD-12S from 300Hz to about 60 Hz, and a dedicated subwoofer from 60 Hz down. My wife is tolerant of this hobby, but I don't know how tolerant she would be of having to turn on the CD player, preamp, crossover, and 4 amplifiers to listen to music. I'm already getting comments about how difficult it is to work my bi-amped setup today. |
| PCBs & KITs for QUAD FAMILY... | crazytuber | Swap Meet | 2 | 12th October 2008 10:03 AM |
| FS: Two DX HDII parts kits and pcbs | cwujek | Swap Meet | 6 | 28th January 2008 05:01 AM |
| LM3886 & snubberPS PCBs and maybe kits (UK/EU) | jimbo1968 | Vendor's Bazaar | 0 | 9th December 2006 04:44 PM |
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 17th May 2005 12:58 AM |
| 2 Ohms stable Transistor Amplifier... | SkinnyBoy | Solid State | 14 | 1st April 2003 02:27 PM |
| Page generated in 0.10597 seconds (86.46% PHP - 13.54% MySQL) with 10 queries |
