Old 12th February 2004, 08:25 PM   #1
Thunau is offline Thunau  United States
Thunau's Avatar
Default Is this safe for OPA2134?
I built a 3 way crossover using ESP boards. I'm using OPA2134s. They have a rather nasty way of powering down, by dumping a sizeable near DC swing on the outputs. I was going to install a normally closed relay across the signal and ground on the outputs and power it from the 5V output of my switching PS. When I power up it will open the contacts and let the signal flow to the amp. When I power down it will close and the DC swing will dump to ground. Is it safe for the output buffer opams? There are 110 Ohm resistors on the outputs used to prevent oscilation.
"Most people just say what they know, the wise ones know just what to say."
Old 12th February 2004, 08:51 PM   #2
PMA is offline PMA  Europe
PMA's Avatar
Output short-circuit is unlimited in duration, but this is an overcurrent, not short circuit. Probably nothing wrong will happen, but ...
I would prefer NO contact with delayed ON function (NE555 timer e.g.).
Old 12th February 2004, 09:18 PM   #3
5th element's Avatar
?? Just powerdown your poweramps before you turn off the active. And visa versa, power up the active xover before the power amps. This is all I do and I avoid and nasties.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 13th February 2004, 02:27 AM   #4
Thunau's Avatar
That's what I have been doing all along, but it takes about 40 seconds for the caps in the amp to discharge when there is no music playing. I just wanted to make a more elegant solution than standing there waiting for the amp to power down before flipping the power switch on the crossover.
Old 13th February 2004, 03:51 AM   #5
tool49 is offline tool49  Canada
tool49's Avatar
This might sound silly, but why not just always leave the crossover on? These thing should have a quiescent current of a few mA at a few volts... not likely to get your electricity bill any higher....
Or perhaps use a relay on the amps to shut them off as soon as you remove power from them.
Sébastien
Old 13th February 2004, 08:43 AM   #6
mskeete is offline mskeete  United Kingdom
Use a relay as you first suggested but changed the output resistors to 680 ohms
Old 13th February 2004, 08:53 AM   #7
Vix is offline Vix  Yugoslavia
Vix's Avatar
I had the same problem. I solved it in a "silly way". I leave the crossover powered on all the time, except when I leave home for longer periods. Since the transformer is small, I don't think it will make a difference on your electricity bill:-)
Vix
Is there any better OP than OPA2134 Progg70 Solid State 95 15th March 2007 07:15 PM
what to do with OPA2134? kmj Chip Amps 3 12th January 2005 08:38 PM
Hakko 936 - ESD safe vs. non-ESD safe KT Parts 2 20th June 2004 03:58 AM
OPA2134 vs. AD8610 bmwrob Parts 35 25th December 2002 07:22 AM
OPA2134 or OPA2604 JoeBob Solid State 5 7th January 2002 11:20 AM
Page generated in 0.10650 seconds (73.53% PHP - 26.47% MySQL) with 10 queries
