Designing Class A amplifier with low output impedance
Old 11th October 2015, 11:40 PM   #1
Schrockwell is offline Schrockwell  United States
Schrockwell's Avatar
Default Designing Class A amplifier with low output impedance
I have designed and built a simple Class A amplifier to drive headphones. The output impedance of a Class A amp is too high, and I am trying to transform it to something much lower – on the order of 1Ω – so that I can drive low-impedance headphones (e.g. 32Ω Grado SR-80).
I tried using a common collector (emitter follower) as an impedance transformer, but even that output impedance was too high – I measured around 60Ω. If that could be lowered, I'd love to use that design and keep everything BJTs, but I could not find a way.
I hit upon the idea of using a unity-gain op-amp (OPA275) to act as a buffer (see attachment), similar to how the O2 works, except with a biased input. It simulates great, but when I built it on a protoboard it is EXTREMELY noisy – there is a very loud hiss when the op-amp is connected to the output of Q1. I expected it to be dead silent, since the output from Q1 alone is dead silent, and the op-amp has unity gain and is also dead silent without any input connected.
So, what gives? Why is the op-amp so noisy? Is there a better impedance transformer design I could use?
(Notes: VCC is 15V. R10 and R11 (10Ω) are just there to make LTspice happy. They're not in the actual circuit.)
File Type: png Screen Shot 2015-10-11 at 7.18.14 PM.png (58.3 KB, 400 views)
Last edited by Schrockwell; 12th October 2015 at 03:03 AM. Reason: Adding schematic notes
Old 12th October 2015, 04:49 AM   #2
Monte McGuire is offline Monte McGuire
The standard way to lower the output impedance of a class A transistor stage is to increase the bias current. The transconductance 'g' is roughly equal to 40 * Iq, and the output impedance is roughly 1/g. So, crank up the bias, and you lower the output Z.
Re. the "OPA275" buffer - is it really an OP275? ;-)
It's not clear to me what the DC bias values are at the input of the OP275. I'm too lazy to simulate, but the DC value at the collector of the transistor could be as low as 0.6V or so above ground. According to my datasheets, the input common mode voltage range of the OP275 is a lot narrower than "right next to the rails", around 4.5V away from the plus or minus rail. So, if you stuff 0.6V into the input stage, and it's not going to be happy with anything less than 4.5V, it may well be horribly noisy.
To solve this, you could use bipolar supplies, bias the transistor stage "up", so the collector ends up at 5V or higher, or use some sort of coupling cap arrangement into the OP275 and a pair of resistors to bias the OP275 input halfway between the supplies.
Honestly, a different circuit would work a lot better. Nobody uses a common emitter stage to drive a low impedance load - they're typically used for gain, loaded into a high-Z. Emitter follower stages are typically used to drive low-Z loads. One could add an emitter follower stage onto your common emitter stage, instead of the op amp, and it could work pretty well. By choosing a suitably low value for the emitter follower's emitter resistor, you can select the bias of that stage, and dial in exactly the output conductance you want. I'd also consider using a different bias scheme for the first transistor than just the 470K to the base - use a two resistor divider so you can stay away from the negative rail and end up with some voltage swing, after you get all the rest sorted out.
Best of luck!
Old 12th October 2015, 05:25 AM   #3
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Driving a 32ohm load you only need a couple of volts swing - the bias current for your output transistor needs to be around 70mA. At that level of bias, the output impedance will easily be below 1ohm for an emitter follower.
Using an opamp won't be classA unless you add external biassing to it.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 12th October 2015, 05:27 AM   #4
First off, thanks for the great response. Yeah, it's OP275 – slip of the brain. It's just what I had lying around, and I figured it would be okay even though I'm not actually amplifying anything.
Good catch on the bias voltage being too low – it definitely is, it's only about 3.5V which is indeed less than the specified 4.5V input for the OP275. I will play with the biases both before and after the BJT and see how that helps.
I had tried an emitter follower but I couldn't get the output impedance low enough. I may give that another shot.
Old 12th October 2015, 06:21 AM   #5
abraxalito's Avatar
As Monte said, the output impedance of an EF has a fairly simple equation - 1/gm (gm here means 'transconductance' - a measure of output current(A) per input volt). The gm is calculated from 40*Iq - for 70mA this gives gm=2.8S and hence output impedance will be around 0.3ohm. If you then use the gain of the opamp (considerable) by including the EF in its feedback loop, the output impedance will drop to an almost immeasurably low level.
I reckon you're better off using the opamp to drive the transistor, rather than the other way around
Old 12th October 2015, 06:36 AM   #6
Mooly's Avatar
Have a look at the output stage here. This would transfer over to silicon with no problems other recalculating a couple of resistor values.
http://www.diyaudio.com/forums/headp...phone-amp.html
Old 13th October 2015, 08:06 AM   #7
sgrossklass is offline sgrossklass  Germany
@OP: So what did you use for a power supply? Are you aware that the common emitter circuit has just about zero PSRR? If it's quiet on its own, that might be just because it has a very high output impedance (namely about 10k) - a 32 ohm load is quite a different story than an opamp input.
I wouldn't want to rule out oscillation either. There was no mention of power supply decoupling.
70 mA of emitter current would usually be a bit too much for a 2N3904, something a bit more beefy is recommended then. Usually a push-pull buffer is recommended for less inefficiency, within the feedback loop - then you can have the opamp do voltage gain, too.
Old 13th October 2015, 08:28 AM   #8
R.I.P.
Your amplifier (Q1) is set up with a gain of 10 (+20dB). It is not an emitter follower. It is common emitter !!!!
Why?
Does your signal need that much gain to drive low impedance headphones?
regards Andrew T.
Old 14th October 2015, 06:48 PM   #9
@The gm is calculated from 40*Iq - for 70mA this gives gm=2.8S and hence output impedance will be around 0.3ohm
abraxalito: What is Iq? To me that means quiescent current, which I assume is the DC collector current on the output BJT when the input is grounded, is that correct?
What I found was that by decreasing the emitter resister I could indeed reduce the output impedance, but it was still being loaded down by a low-impedance load (i.e. the overall gain was noticeable less with 32Ω load versus an open). See attachment, with 70 mA of bias current running through Q4.
@Mooly: Cool, thanks. It's interesting looking at an "upside down" design. If I understand correctly, Q3 is your "emitter follower" (sort of), and Q4 and Q5 combine to create a constant current source, which would deter a low-impedance load from drawing so much current away from the output transistor. Is that true, or an oversimplification?
@sgrossklass: Hm, I did not know that about PSRR. I am using a simple full-wave rectifier with an LM7815 (see attachment). I will probably want to double up on C4. Right now I'm actually using an LM1086 fixed at 15V because that's what I had handy. Simulated ripple in the output is 360 V, but I guess the regulator could add noise too, huh?
I agree, 2N3904 is wimpy. It's a placeholder for now so I can understand the basics and what specs are important before picking a real part.
@AndrewT: Yes, I was referring to adding an emitter follower as an output stage. Sorry if that was not clear. A gain of 10 is pretty excessive for a headphone amp, I agree I will probably dial it down.
File Type: png Screen Shot 2015-10-14 at 12.41.04 PM.png (62.0 KB, 238 views)
File Type: png Screen Shot 2015-10-14 at 2.41.12 PM.png (36.5 KB, 217 views)
Old 15th October 2015, 03:50 PM   #10
Here's the latest and greatest. I replaced the output stage with a Darlington pair. I haven't breadboarded it out yet, but Q5 will be bumped up to something beefier and heat-sinked (I have a TIP48 handy), since it draws 100 mA just sitting at DC. The resistors R10, R11, R15, and R16 can consume up to 250 mW apiece, so those will have to be 0.5W resistors I suspect. Seems pretty inefficient.
I biased up the amplification stage and reduced the gain to 6X (15 dB). I also added C7 to the input to form a low-pass filter with R3, which has a 3 dB cutoff at 75 kHz.
THD is less than 0.15% for loads from 32Ω - 300Ω at 0.5 VRMS output, which is more than sufficient for headphones. That's the best THD I could find with this topology. At higher drive levels the distortion from the phones themselves probably dominates, anyway.
Thanks for all the feedback so far. I'm learning a lot very quickly and appreciate the help. What are some potential pitfalls I have missed?
I also have a delayed turn-on delay circuit with a relay, but by increasing C2 to 1000 F, the DC offset on the output takes a long time to settle down (< 10 mV) more than 10 seconds. At what level of DC offset is it safe to turn on the output, provided that the initial "thump" is skipped?
File Type: png Screen Shot 2015-10-15 at 11.24.44 AM.png (113.0 KB, 189 views)
Designing Class A amplifier with low output impedanceHide this!Advertise here!
High voltage, low current output stage for class D amplifier ionomolo Class D 46 30th December 2017 11:35 PM
Opamp Class B amplifier output impedance amendiola Solid State 24 13th August 2015 06:26 AM
Class D and low impedance load epilot Class D 8 10th July 2011 12:58 PM
Designing x-over when amp output 2.3 Ohm impedance Cousin Billy Multi-Way 2 10th March 2011 02:32 AM
Possible to design a high-power class D amp with a low output impedance? 454Casull Class D 2 23rd February 2009 07:33 PM
