Old 12th February 2004, 01:22 PM   #1
saurus is offline saurus  United States
Default How do I ground this?
Please help! I have added an output buffer to a DAC that I built, and I can't figure out how to ground the thing. Here is what I have:
The 16vac from a single secondary (two wires) is split, with the first split going to the DAC's single-sided power supply (+5vdc/gnd). The signal and shield ground from the digital input RCA jack goes to the DAC board.
The second AC split goes to the buffer's dual power supply (+15vdc/0/-15). The signal from the DAC's analog output goes to the buffer input, but not the signal ground. The signal and ground to the analog output RCA jacks comes from the buffer board.
There is currently no direct connection between the DAC circuit and the buffer circuit, except for the AC in and the signal trace. I tried connecting the 0v center lead from the buffer's dual supply to the ground of the DAC's single supply, but that promptly blew the fuse. Now the thing puts out only a terrific 60(?) Hz hum.
What is the common connection between the two circuits, or is there one? How do I handle the grounding for this?
Thanks for any help you can give.
Old 12th February 2004, 04:25 PM   #2
lucpes is offline lucpes  Europe
Send a message via Yahoo to lucpes
Default Re: How do I ground this?
It is best to use complete separate power supplies in this case (or at least two secondaries). At this size another trafo won't kill your wallet so go for that!. In theory the sound quality should be better so the only drawback is the small added cost.
I had similar troubles when building two 'simple' PS's using 7815 & 7915s for a 'dual channel' preamp and the only sollution was to buy another small toroid.
Old 12th February 2004, 07:02 PM   #3
Thanks for the advice. I will get another transformer if I must, but is this really the only way? Since both power supplies are drawing from the same AC secondary, is there no common ground between the two circuits?
Old 12th February 2004, 08:09 PM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Can you draw a circuit? How are the diode (bridges) connected? This IS a power supply, or what?
Jan Didden
Old 12th February 2004, 08:53 PM   #5
Thanks - Here is a schematic of sorts showing what I have:
Old 12th February 2004, 09:04 PM   #6
Jax is offline Jax  Sweden
Short term solution: remove B1 and connect the IN of the 5V regulator to IN of the +15V. Connect the grounds of all regulators together.
Long term: use another transformer for the 5V supply.
Jan
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
DC filament ground and high voltage ground mikeyho Tubes / Valves 0 15th September 2005 05:52 PM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 01:08 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 3 28th February 2003 05:31 PM
Page generated in 0.09549 seconds (75.89% PHP - 24.11% MySQL) with 11 queries
