Alesis RA-100 Oops - Need Help Please - diyAudio
Old 2nd October 2015, 03:15 PM   #1
Default Alesis RA-100 Oops - Need Help Please
I have an Alesis RA-100 that has developed an audible hum while just sitting. It has been well cared for and never abused. After reading some of these threads I decided to take the cover off and inspect the inside to see if there was any outward indication of the source of the problem.
In doing so, I decided to replace the big capacitors in the power circuit. This because everything else looked to be secure, the transformer was solidly attached etc. Before I took out the power PCB I took a photo with my phone and took it out. I got sidelined by a few things and in the meantime my phone died a horrible death. So, I no longer have access to the photo.
I am left with a black wire coming from E41 on the PCB that is unattached and I cannot remember where its ring was attached. The wire is short so I do not think it can go very far. I have downloaded the schematic I found on the web and it does not (as far as I can tell) designate a connection for E41. I am not very good at schematics though.
Can anyone tell me where it goes?
Old 6th October 2015, 02:19 AM   #2
maybe you can post the schematic here.. also the black wire your talking about..
Old 6th October 2015, 10:45 AM   #3
vzaichenko's Avatar
Send a message via Skype™ to vzaichenko
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
Old 6th October 2015, 11:02 AM   #4
e41 is most likely a silkscreen (component side) board designation,the schematic won't show that. so tracing back from the wire can you find the nearest components on the trace it's attached to? most likely the "external gnd" which should go to a terminal on the case maybe?
Alesis Ra-100 repair help Shredasaurus Instruments and Amps 7 20th February 2015 08:19 PM
Alesis RA-100 - may need a new transistor deniss77 Solid State 28 22nd December 2014 06:47 PM
Alesis RA-100 Repair Kamuy Solid State 45 17th July 2013 02:40 PM
ALESIS RA 100 - Schematics fosforo Solid State 8 16th March 2012 01:31 AM
Schematic for Alesis RA-100... Ha! Alesis doesn't have it!! crispycircuit Solid State 0 22nd February 2010 09:16 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
