2SK194 dual Jfet for LTP input...
Old 1st October 2015, 04:33 AM   #1
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
Default 2SK194 dual Jfet for LTP input...
I got 17 pieces of this old dual Jfet ...can somebody help me where to use this thing....I plan to use this as LTP input for power amp since they are pretty matched...
Does anybody has some schema to share or guide me to good working schematics...best if there's available PCB layout.
Old 1st October 2015, 05:05 AM   #2
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Jun, know someone looking for those, will you be willing to sell a pair?
a phono stage can use those....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 1st October 2015, 05:36 AM   #3
Junm's Avatar
Yes sir i can share a pair...just PM me
I want them in an amp input and see what they do...i think sony use this as amp input....the 2sk147 is the half equivalent of this..
Old 1st October 2015, 06:50 AM   #4
Calvin is offline Calvin  Germany
Calvin's Avatar
here´s a Datasheet from NEC.
On first glance it looks to be a superb MC-Inputstage device with its very low enoise and high gm.
Unfortunately those features also come with high input capacitance.
They are quite close to Toshibas SK369 and -apart from capacitance and speed- the single BF862.
If used in a MM-Input stage it needs to be cascoded, to keep input capacitance of the stage just acceptably low.
A I/V converter stage like EUVL´s Zen might also be a nice circuit for them.
I wouldn´t ´waste´ them for Input stage devices for a line level or power amp.
jauu
Calvin
File Type: pdf 2SK 194 Dual super lownoise N-channel NEC.pdf (62.6 KB, 64 views)
Old 1st October 2015, 07:03 AM   #5
Junm's Avatar
Thanks...any schematics link for those...
Old 1st October 2015, 01:37 PM   #6
R.I.P.
I agree with Calvin.
Use them in something special and cascode them.
Have a look at Salas RIAA pre.
There will be others.
Oh and prove to yourself they are genuine start with the really easy Idss @ 5Vds (unusually low cf. the normal 10Vds used elsewhere). Follow up with Vp. Borbely shows a little jig for these two measurements.
Find those that make really good pairs. Batch them into mA Idss.
regards Andrew T.
Old 1st October 2015, 01:43 PM   #7
R.I.P.
They would make great swap devices to someone willing to part with well matched k170/j74
A pair of these k194 could be worth a fair bit of money !
regards Andrew T.
Old 2nd October 2015, 01:19 AM   #8
Junm's Avatar
I will set up a test Jig and see...these are sure genuine since they are from and old electronics store whom i accidentally found on disposal items wrapped in a nice anti static plastic.
Thanks andrew....I might swap the other for k170/j74 but my worries most of them are fakes...
Old 2nd October 2015, 07:07 AM   #9
R.I.P.
You must get a full money refund GUARANTEE including return postage before buying from anyone.
There are a few sellers here in the Forum.
regards Andrew T.
2SK194 dual Jfet for LTP input...Hide this!Advertise here!
Jfet complimentary input stage or Jfet LTP? rhythmsandy Solid State 16 26th July 2015 04:21 AM
Suggestions for single & dual DIP-8 jfet input opamps? rol Solid State 1 5th June 2014 04:08 PM
FS: PreAmp with Complimentary JFET Diff input & JFET ouput USAcircuits Vendor's Bazaar 12 21st June 2011 11:02 AM
JFet matching and measured distortion - Part 2: LTP h_a Solid State 27 27th March 2009 05:40 PM
