Jfet input stage better in sound quality compared to a BJT input? - diyAudio
Old 30th September 2015, 04:58 PM   #1
Default Jfet input stage better in sound quality compared to a BJT input?
thinking to start working on Jfet input amplifier but is it worth enough to use jfets at input stage?
Old 30th September 2015, 05:01 PM   #2
There are probably hundreds of threads here in the forum about this, searching around will give you many different opinions and proven designs to back up those opinions.
There is no better, there is different flavours.
Old 30th September 2015, 05:06 PM   #3
RJM1 is offline RJM1  United States
Only if it is being driven by a high impedance source.It might be useful if you are using a tube preamp but not with anything that can drive a 1K load.
Old 30th September 2015, 05:08 PM   #4
DPH is offline DPH  United States
Ask yourself what exactly you want to do, what your design specifications are, then design to that. FET input might be better, we don't know.
Where is Bruno when you need him? Penultimate slide: http://www.hypex.nl/docs/papers/AES123BP.pdf
Old 30th September 2015, 05:32 PM   #5
John Curl, Nelson Pass, Charles Hansen, and Constellation Audio design with and bought up all the Toshiba jfets - guess why
Old 1st October 2015, 05:31 AM   #6
How to increase the voltage operation of this circuit to +/-100V?
http://m.eet.com/media/1196048/F11large.jpg
Old 1st October 2015, 06:20 AM   #7
ostripper's Avatar
Add a cascode between the Jfets and mirror.
Using the jfets in a blameless .... your would have the "voice" of the
current sourced VAS.
There are better circuits to take advantage of a jfet LTP. Older
sansui 3 stage designs or a cascoded "symasym" would be the
ticket.
I've built and heard both BJT/FET IPS's , less gain with FET's. No
real SQ differences. The VAS and output stage are bigger factors.
The other guru's buy up the fet's to perpetuate another urban legend.
Edit - (below) is a far more advanced version of what most 1970-80
Japanese JFET LTP audio amps were. Works flawlessly with just
about any Jfet.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 1st October 2015, 06:34 AM   #8
kamis is offline kamis  Serbia
They made a huge stock of Toshiba j-fets, created a good audio story, and are selling them slowly more expensive than diamonds. They say that LS j-fets are not good enough compared to Toshiba.
Old 1st October 2015, 07:01 AM   #9
I think these days the secret is to stock good parts..
Old 1st October 2015, 09:00 AM   #10
ticket.
about any Jfet.
OS
BJT or Jfet cascode?
1. Any other better transistor than 2N5401? as ON semi and Fairchild have stopped them so how about using KSA1381? the cob is impressive but im sure any other transistor with lower cob?
Complementary JFET-JFET cascode input, BJT VAS-Drivers, Lateral Output Neutrality Solid State 61 2nd October 2015 06:35 AM
Adding a Jfet input stage for the power amplifier improves sound quality? rhythmsandy Solid State 1 29th June 2015 08:02 PM
bjt jfet CFP diff input stage robydream Solid State 14 27th July 2014 04:29 AM
New preamplifier kits with JFET or BJT input stage PMA Vendor's Bazaar 10 11th September 2011 12:38 AM
Complementary diff input with JFET and BJT cascode Bensen Solid State 126 16th October 2006 05:35 PM
Copyright 1999-2017 diyAudio
