#11 | |
The characteristic impedance of RCA I wouldn't worry about, in a typical audio interface the source is a voltage generator with very low impedance and the receiver is of high impedance which means that reflections are terminated at source and therefore they are not a problem. Even if the system would be made with 50ohm sending amd receiving impedance any imperfections would have almost no effect as the wave length is so much longer then the cable length thereby minimising impact of reflections. For better audioconnectors there are many alternatives on the market like XLR, mini XLR aso but RCA is de facto standard so it is difficult to change but it is of course possible. Regards Hans |
#12 | |
I'd like N connectors on an audio amp. In fact, I think I might like heliax cable interconnects also. |
#13 | |
SMA connectors for LAB equipment are often made of stainless steel or plated with special plating and made for repeated connections but they are much more expensive then ordinary cable connectors. Regards Hans |
#14 |
Impedance matching at audio frequencies is totally meaningless since the characteristic impedance of a transmission line is frequency dependent.
See link http://home.mira.net/~marcop/ciocahalf.htm Nothing wrong with SMA connectors, they do their job even at audio frequencies. I would not use them, they are difficult to work with. RCA connectors can be used at VHF frequencies with good result.
Jan |
| WBT connectors | Freddie | Parts | 6 | 25th November 2006 08:50 PM |
| 5 and 7 pin connectors | SRMcGee | Parts | 9 | 22nd September 2005 11:32 AM |
| PL connectors ?? | darkm4n | Parts | 3 | 10th March 2004 04:07 PM |
| Page generated in 0.09327 seconds (71.35% PHP - 28.65% MySQL) with 10 queries |
