Trying to fix an old Marantz PM-35MKII - diyAudio
Old 12th September 2015, 12:44 PM   #1
zdr is offline zdr  Belgium
zdr's Avatar
Default Trying to fix an old Marantz PM-35MKII
Outputs were completely dead when I got it, but headphones were playing just fine. Checked the schematics and noticed that there is speaker protection relay in the output stage, but there was no clicking sound on power on/off Indeed, the relay coil was burnt. An aluminum foil around the 1A fuse might had something to do with it
Replaced the relay and the shortened fuse, and now on to a new problem: protection circuit excites the relay as soon as volume is turned just a little bit above dead silence. At the same time, trafo starts singing the music that is supposed to come out of the speakers, at higher volumes
Did not start the measurement yet, but wanted to share findings so far in case it's a known issue with this amp.
http://akdatabase.org/AKview/albums/...0Schematic.pdf
Old 12th September 2015, 01:45 PM   #2
Mooly's Avatar
Sounds like a short on the speaker output somewhere, the protection tripping due to overcurrent. Just measure the resistance across the speaker terminals for a start.
As the unit seems to have been 'got at' I would look closely to make sure no other unauthorised mods have taken place
Old 12th September 2015, 02:54 PM   #3
Welcome is offline Welcome  France
Welcome's Avatar
Check output transistors. Probably all blown. Same for driver transistors and emitter resistors.
Marantz PM-94 StuartMoore Solid State 21 23rd February 2011 08:33 PM
Marantz PM 440 and PM 351 Schematic required Krokotam_ Solid State 0 22nd October 2008 07:36 AM
Marantz PM 75 Mat Solid State 6 20th January 2006 06:54 AM
Marantz PM 55 elec972 Solid State 0 6th December 2005 11:57 PM
Marantz Pm-66SE geddam Solid State 2 28th April 2005 02:15 AM
Copyright 1999-2017 diyAudio
