Just built a JLH96 using this schematic:
I built it on a breadboard, point-to-point. Everything started out fine... I set my power supply for 0.2 amps and 0 volts. Attached the power supply, turned it on and rolled the voltage up to 2 volts. So far so good. I increased the voltage to 5 volts. All good. Then I went to 10, 15 and finally 22 volts. No smoke!
I have an 8 ohm 35 watt resistor attached to the output terminals. The dc offset was ~76 millivolts so I used VR1 to reduce it to 0 volts. Everything still seems good.
Next I increase the current to 1 amp. After which something must have blown. I didn't hear or smell anything but I could't read any voltage on the output terminals any longer. I turned the power supply off and waited a few minutes. Turned it back on and tried to change the dc offset with VR1 but it had no effect. The output transistors never got warm.
I have no idea where to start or how to begin troubleshooting this thing. Could anyone give me an idea of what to check or where to start??
Thanks much for your help -
Bruce
Bruce
Breadboard ? If it didn't include a large heatsink you've fried the outputs.
rgds, sreten.
Thank you for your reply sreten, I'm using this one:
Hi abpea,
Frustrating! Look there is a very large thread here (over 3,000 posts) on this amp/circuit at "JLH 10 Watt class A amplifier" (use search function). That is where all the JLH aficionados/gurus hang out. I think you'll get a quicker response from them if you post your question there. And that thread is also frequented by very civilized and helpful people.
Jonathan
Jonathan
Abpea now now moved to the JLH Thread
http://www.diyaudio.com/forums/solid-state/3075-jlh-10-watt-class-amplifier-156.html#post4448622
Could we now close this Thread?
- Help Troubleshooting JLH1996
