Finishing Amp
Finishing Amp
Old 7th September 2015, 10:05 PM   #1
Ripcord is offline Ripcord  United States
Ripcord's Avatar
Default Finishing Amp
I'd like to get opinions on the bits and pieces required to finish up a solid state power amp. Take, for example, a simple circuit like the one posted. Obviously it needs a power supply, heatsink, a case, connectors, knobs. What about things that aren't so obvious. Does it need fuses? And where? Input, rails, speaker. What about DC protection? Speaker protection? Softstart? I'm not asking what this particular amp circuit needs but rather what do you guys think are some of the more important add-ons to turn a simple circuit in to a useable, safe amp.
P.S. Please move if it should go in the construction thread.
Old 8th September 2015, 02:59 AM   #2
gannaji is offline gannaji  India
gannaji's Avatar
subscribed!
www.samritatrust.org
Teach me the glorious lesson that occasionally, I might be mistaken. Keep me reasonably sweet.
Old 8th September 2015, 03:12 AM   #3
rayma is offline rayma  United States
You definitely should have an AC line fuse. Most commercial amps also have rail fuses.
Since you have a direct coupled output, you may want a series relay that opens if DC is
present at the output, as when a fuse blows, to protect the speakers. There also should
be a resistor to ground before the input coupling capacitor to avoid pops, such as 100k.
New Soft Start & Speaker Turn-On Delay and DC Protector Boards (Set of 2 boards) - Power Supplies and Accessories - Circuit Boards
Old 8th September 2015, 08:36 PM   #4
Ripcord's Avatar
Thanks rayma. I thought a few of us might be interested in this info. There are so many simple circuits, ss and tube, on the diyaudio site, that just show the basics. I know I could learn more about making an amp safe and reliable.
Finishing AmpHide this!Advertise here!
Finishing a custom made power amp... Luke123 Solid State 9 18th April 2014 08:57 AM
Finishing up chipamp! Dougie085 Chip Amps 132 6th November 2007 09:25 PM
An other finishing fung Multi-Way 16 10th April 2006 04:12 AM
Quick question re: finishing up my sub enclosure & mounting driver CUclimber Multi-Way 1 18th April 2004 06:46 AM
