SU-Z400 improvements?
Old 7th September 2015, 05:20 PM   #1
wheijke is offline wheijke  Netherlands
Default SU-Z400 improvements?
Found a dead cheap SU-Z400 'broken' which basically has a broken speaker connector which is easy to replace. It seems to work fine!
I read on another forum that someone replaced IC71 (AN7062) with a fresh one and upgraded Q71 and Q72 (2SA1123) to 2SA1124..
Are there any other things people recommend to do on this amp?
Wouter
naks.com and vintagecassette.com my websites dedicated to Cassette Decks!
Old 7th September 2015, 06:41 PM   #2
R.I.P.
Generally for cheap stuff, if it ain't bust don't try to fix it.
Replacing working IC's is pointless and changing working
transistors is asking for more trouble than it is ever worth.
rgds, sreten.
Old 7th September 2015, 07:21 PM   #3
Ian Finch is offline Ian Finch  Australia
Replace all the electrolytic capacitors and for as long as the rest of it hangs together, be happy
If only I had listened....
Old 7th September 2015, 08:18 PM   #4
Welcome is offline Welcome  France
Welcome's Avatar
Replacing 2SA1123 with the +1 is a waste of time and money. Only difference is higher SOA, something you do not need as the amp was designed around the 1123. Fully useless change. Not to mention if you get ahold of some 2SA1124, they will be fake. No longer made.
SU-Z400 improvements?Hide this!Advertise here!
Panasonic SU-2700 Repair (Otherwise known as the Technics SU Z1) MChandler Solid State 22 11th April 2013 07:25 AM
Technics SU-Z400 problem exzlr8 Solid State 8 23rd April 2010 07:44 AM
Technics SU-Z400 ironfinger43 Solid State 2 26th June 2009 02:18 PM
old technics SU-Z400 cutcat Swap Meet 1 27th December 2006 12:53 PM
