#11 |
I suggest simple series pre-regulation based on a couple of 60V 60A mosfets, they are cheap and very easy to drive if you pick the right topology [source as input, drain as output, with floating transformer windings for symetric regulation]
If supply drops to +-75V at full power and you adjust output to 80V then dissipation in the regulators will be very low as they will be fully switched-on most of the time I've used this stupid technique to power 12V car ICs [max. 18V] with 17V regulated [up to 28V before regulation], using cheap transformers and small filter capacitors, to get cheap and simple 25W/channel PA amplifiers for 100 Volt lines [transformer coupled outputs] |
#12 | |
Eva, any sample schematics I can review? The amp in question is an Adcom 555. the trafo is 700VA or so and the AC is pretty well regulated, i.e. secondary voltages drop only from 60vac to 56 vac or so. It is the DC side that drops hard. Each channel has 30,000uF caps which is not huge but its not puny either. What I am trying to do is use it to drive a couple of Woofers and need about 60 volts RMS produced by the output stage. I reckon with +/- 100 vdc rails I can get that. Any more ideas are welcome!!! |
#13 | |
What I am trying to do is get more power by jacking up the output stage voltages to 100vdc and drop the same to the input stages. Thereby keeping it around 80vdc at the input stages and let the output stage rails go up and down with load. Again my aim is not to have a rock solid 80vdc at the input stages but merely to drop 15-20 volts from the main 100vdc rails... I want to keep it simple for my prototype. thanks in advance. |
#14 |
there are lots of options to lose the 20v for the low power parts,
the difficult bit is maintaining the 80V under high load. Simplest is using RC filtering, dimension R according to the class A standing current in the input stages to give a 20V drop, you then need to add enough C to maintain the voltage high enough under high output load transient conditions. Simulation is probably best, but I'm sure 470 uF would work well. edit : add a series diode to prevent the C reverse discharging into the main supply capacitors. edit : from the sound of it a seperate small rectifier with the RC filtering would also help matters, here you need CRC filtering. |
#15 |
You should take into account that this voltage drop in the power supply is sometimes used as a trick to make amplifiers work with 4 ohm or 2 ohm loads without exceeding the SOA of the output devices
I have seen lots of PA amplifiers whose no load supply voltages are way too high to be reliable, but low VA high V transformers and smaller capacitors are cheaper and protect the amplifier when working full power at low impedances It would be a great idea to check SOA of output devices |
#16 |
Agreed EVA, the originals are the old trusty Toshiba D424/B554 pairs but for 100vdc rails, I plan to use MJ21193/94 pairs. About 4 pairs per channel. It should work.
Sreten: A schematic would help me a lot. thanks yet again all you guys. K. |
#17 |
Sreten:
I re-read your post. It makes a lot of sense for my application. Question: would a lower R value shorted by an 80v Zener help regulation? Also the C, I am thinking to install much larger values like 2200uF or so. One would think the more the merrier but then they would take longer to charge up and who knows what kind of secondary issues I have with oscillations and/ or power on thumps because the Adcom does not have a delay circuit. Your thoughts? thanks! K. |
#18 |
Read these for power supply design. It will cover up most of the issues you may deal with:
http://sound.westhost.com/power-supplies.htm http://www.tnt-audio.com/clinica/ssps1_e.html |
| Easiest way to cut PCB's? | Dr.H | Parts | 38 | 25th May 2010 11:51 AM |
| The easiest way to reduce box volume | DAMIC | Multi-Way | 7 | 17th July 2009 05:51 AM |
| Easiest way to correct this dip? | JCoffey | Multi-Way | 12 | 11th June 2007 12:52 PM |
| HP stage modulates rails in tape deck. How can I reduce this problem? | Triophile | Solid State | 0 | 12th April 2006 09:36 PM |
| cleanest/ easiest EQ | rick57 | Digital Source | 15 | 1st July 2005 03:52 PM |
| Page generated in 0.12116 seconds (83.03% PHP - 16.97% MySQL) with 10 queries |
