studio 350 amplifier - diyAudio
Old 2nd September 2015, 08:10 AM   #1
Default studio 350 amplifier
Hello to all
I would build the amplifier STUDIO 350, but I do not know the number of turns of the output coil L1 (6,8uH).
I need the following information:
1) number of turns
2) wire diameter (1 mm framework suppose, but I do not know if correct)
3) internal diameter of the coil (seeing the photograph of card is used I think is about 1.5 cm, but that's just my guess).
I thank those who can help me.
Best regards.
Old 2nd September 2015, 08:23 AM   #2
6.8uH is getting quite large and will need more wire.
This will raise the resistance if you use thin wire.
I consider 1mm diameter copper too small for a 6u8H air core.
Try 1.5mm or 1.8mm diameter. Or even bigger if you have it.
You will need between 20T and 25T wound around a 14mm to 15mm former. AA battery works.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd September 2015, 08:27 AM   #3
greierasul's Avatar
Send a message via Yahoo to greierasul
Coil Inductance Calculator -
Old 2nd September 2015, 08:29 AM   #4
There is a calculator here; Air Core Inductor Coil Inductance Calculator
applying to an air core inductor, if that is what you want to use.
a iron former can assist to confine and make the number of windings
much smaller.
For 6.8uH using an air core type you will need
Coil diameter 0.3 of an inch
Coil length 0.69 of an inch
Number of turns 50
Cheers / Chris
Old 2nd September 2015, 09:19 AM   #5
Thank you very much to all !!!
Studio 350 construction thread jamesfeline Solid State 12 2nd September 2015 06:36 AM
Studio 350 Power Amp merlinovski Solid State 0 17th September 2014 04:34 PM
Studio 350 bmurray86 Solid State 28 26th August 2012 10:24 AM
Studio 350 diban Solid State 6 27th April 2010 12:07 AM
350 Studio Amp Dazza Chip Amps 1 22nd January 2006 04:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
