Query on JFET / BJT cascode circuit - diyAudio
Old 31st August 2015, 07:36 PM   #1
pwan is offline pwan  United Kingdom
Default Query on JFET / BJT cascode circuit
I try understanding how BJT cascoded over the JFET work ( the last fig./5.7 of the following link.)
ESP Amplifier Basics - How Audio Amps Work (Part 5)
1) Since BJT works as common base, current sunk from the emitter causes the transistor to conduct. So, the hfe of BJT doesn't matter -- either its hfe is low as 50 or > 300. Is that correct?
2) How to fix the Vds of Jfet (e.g. at 3V for J310) to let the jfet operate in its triode region?
Thank you in advance.
Cheers
Old 1st September 2015, 01:02 AM   #2
LineSource's Avatar
Nelson Pass has a nice short note on cascodes. There are also several good circuit text books online.
http://www.firstwatt.com/pdf/art_cas_amp.pdf
Class-A operation reduces nonlinearities due to current fluctuations through the transistor, but it does not affect nonlinearities in the transistor due to voltage changes. Cascode operation creates narrow limits in this voltage across the input transistor(FET), significantly eliminating voltage-induced distortions. In the case of JFET inputs operated in common-source mode differential pairs, the cascode bipolar transistor is in the common base mode whose emitter is connected to the drain of the JFET gain transistor. Having essentially unity current gain, extremely wide bandwidth, and no distortion, the common base device shields the gain transistor from voltage changes in the circuit.
Cascode circuits also allow low-noise or high-gain transistors with low break-down voltages to be used in high wattage circuits. The popular 2SJ109 PJFET has a break-down of just 30V.
Old 1st September 2015, 01:55 AM   #3
bwaslo is offline bwaslo  United States
bwaslo's Avatar
To fix the drain voltage of the FET at voltage X, just set the base of the bipolar transistor to about X+0.65 Volts. You can do that with a voltage divider or a regulator. LEDs are often used for this as a shunt regularor of sorts, though usually selected because they also give nice lights!
DIY Synergy horn spreadsheet http://libinst.com/SynergyCalc/
XSim -free crossover designer and simulator http://libinst.com/Xsim/XSimSetup.exe
Old 1st September 2015, 02:39 AM   #4
Billion!
Thank you very much LineSource & bwaslo.
Old 1st September 2015, 12:42 PM   #5
Originally Posted by pwan View Post
....................2) How to fix the Vds of Jfet (e.g. at 3V for J310) to let the jfet operate in its triode region?
I think it is Borbely that tells us to ensure that Vds is at least two times Vp of the jFET.
What is Vp of your j310?
What would be Vds if you stick to Borbely's rule.
Borbely shows a little test jig that measures Idss, Vgs @ Id and Vp by just flicking a couple of switches.
BTW,
Borbely uses jFET cascodes because he moved over to FETs in a big way during his career.
He did show BJTs as cascodes in some locations in his very earliest designs.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old Yesterday, 12:09 AM   #6
andyr is offline andyr  Australia
Originally Posted by AndrewT View Post
BTW,
Thanks for the links to the Borbely articles, Andrew.
Andy
Pass bjt cascode amplifier from the 70s or 80s.. GregH2 Pass Labs 48 4th April 2012 08:54 AM
Complementary JFET-JFET cascode input, BJT VAS-Drivers, Lateral Output Neutrality Solid State 53 23rd October 2011 06:53 PM
Best voltage reference device for a cascode BJT CCS? ray_moth Tubes / Valves 2 1st July 2009 09:38 PM
Did I get this JFET Cascode right? KP11520 Digital Source 28 24th September 2007 04:16 PM
Complementary diff input with JFET and BJT cascode Bensen Solid State 126 16th October 2006 05:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
