Do my Exicon MOSFETs look genuine? - diyAudio
Old 17th August 2015, 09:36 AM   #1
Kev06 is offline Kev06  England
Default Do my Exicon MOSFETs look genuine?
I bought some Exicon ECX10P20R/10N20R lateral mosfets back in 2013, and am just coming up to using them (after an unexpected delay). Back then, Profusion was unable to get any stock (I believe the manufacturers had a flood or something and production ceased for a while) so for better or worse I bought them from.... ebay.
I should say that I've no reason whatsoever to suspect that the UK seller (lyn3009 / Electronic Bits and Bobs) or the mosfets are not 100% genuine, the seller has a good record and no suggestion of dishonesty in their feedback, I just have a general distrust of components on ebay. But the manufacturers aren't big on photographs and profusion only have a tiny thumbnail, so I'm finding it hard to check, short of measurement. Is anyone able to tell by looking if these seem okay?
Kev
Old 17th August 2015, 09:52 AM   #2
Must admit the print looks pretty rough but lateral MOSFETS are not prone to fakes as there pin-out is different to other MOSFETS.
Old 17th August 2015, 10:01 AM   #3
Thats slightly encouraging, I didn't think about the pin-outs. Thanks.
Kev
Old 18th August 2015, 07:53 AM   #4
astx is offline astx  Austria
yours are looking like fakes ...
Here are Exicons bought from Profusion:
Old 18th August 2015, 08:29 AM   #5
Thanks for the info, much appreciated.
Yours are a different model of mosfet (and perhaps manufactured more recently), so I guess its hard to be absolutely certain, but I fully agree they look very different <sigh>
Has anyone else bought my model (ECX10P20R/10N20R) a few years ago?
Cheers
Kev
Old 18th August 2015, 08:34 AM   #6
Mooly's Avatar
Did you do as triplej suggests ?
Yours look typical of small scale production... I'll bet they are genuine.
Installing and using LTspice. From beginner to advanced.
Old 18th August 2015, 09:21 AM   #7
I hope you're right Mooly, I won't give up yet, then. I'll also have to dig my gear out of storage and try to test the pins.
In the mean-time I've done a bit more searching, I can't find a lot but I've run across suggestions that (following some major flooding) the exicon factory may have been reborn anew, so that could explain newer printing methods, as could a larger scale manufacturing run.
I've found several examples that look like mine, but sadly no providence so that isn't helpful. I've also found some newer versions of the same model
that look like ASTX's in style. I'd like to think they're 'so' different that an attempted fake would be more similar, but maybe thats being wishful.
I also found some that were different again, so it all seems a bit muddy. E.g. these
one pair were even completely blank and unmarked.
Kev
Old 18th August 2015, 02:24 PM   #8
dillmeister's Avatar
Here are some pics of the same mosfets I purchased directly from Exicon before and after the supposed flooding incident you spoke of. These appear to be from before as the ones I purchased after the three lines beside Exicon blend together to form a box on the after units. Looking at the before units it says Thailand in the little circle and Phillipines on the after units.
I used to be indecisive, but now I'm not so sure.
Old 18th August 2015, 02:42 PM   #9
sangram is offline sangram  India
The ones in the picture marked 'Polida' are Siliconix vertical MOSFETs. Pin length, finish and the package shape near the 'ears' seem to be dead giveaways.
Which these also might be.
Old 18th August 2015, 02:57 PM   #10
Did it Himself
richie00boy's Avatar
Polida is a known fake seller.
Just get the multimeter out and you'll know for sure. As you bought from a UK seller it is likely they just buy in bulk from Profusion and resell at a profit in low quantity.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
2sk1058 or Exicon lateral mosfets? rhythmsandy Solid State 16 9th June 2014 06:09 PM
Counterpoint SA-100 with Exicon MOSFETs woodman Solid State 28 23rd March 2014 02:25 PM
Exicon lateral MOSFETs davygrvy Solid State 18 6th December 2011 10:56 AM
How do the pinouts on Exicon mosfets work? reiver Solid State 4 11th October 2008 01:27 AM
exicon mosfets STUART Solid State 8 23rd November 2001 09:30 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
