GFA-555 Help Please. (pics attached) - diyAudio
Old 7th August 2015, 11:27 AM   #1
CANADA is offline CANADA  Canada
Default GFA-555 Help Please. (pics attached)
Hello,
I am an original (1986) GFA-555 owner, and I stupidly unplugged the speaker wire plug from one of my 18" EV subwoofers during operation. When this happened, I knew I had blown a fuse.
When I went over to the amp, I saw some smoke coming out from the center which was unusual, and when I opened it up to replace the fuse, I didn't see (or missed) any signs of damage.
Thus, I installed new a new 6amp fuse and fired her up.
Not 5 seconds after turning it on, I saw a bright orange glow and smoke coming from the main circuit board.
Upon further inspection, the 2 outside fuses were blown, and the board has now cooked some resistors and blown apart one of the black (caps?).
I've contacted Adcom, and they say there are no replacement boards available.
So, my question is......Can this be fixed, and how much would a repair like this typically cost?
Any insight would be appreciated.
Thank you so much.
Old 8th August 2015, 06:45 AM   #2
looks like the board is ok, just got to go through it and replace all bad transistors and I would go ahead and replace all the capacitors except the big ones. Definitely repairable!
Old 8th August 2015, 07:37 AM   #3
djk is offline djk
djk's Avatar
You must scrape all the carbon off the board, and then seal it with epoxy (or similar).
Is this a 555II?
What is the number on the board?
(AO34A)?
Candidates for the Darwin Award should not read this author.
Old 8th August 2015, 10:46 AM   #4
Liquid Mids:
Thank-you for the reply. It's a relief to hear that it looks salvageable. Having owned it for 25 years, and thinking I killed it.......was like losing a first born! Lol.
DJK:
The unit is a 1986 GFA-555, and the board is SMKS 394V-0. Thanks for the carbon removal tip. Makes perfect sense.
So now that I know its repairable, does anyone know anybody qualified in Toronto Ontario Canada or within reasonable proximity that can do the repairs for me? I really don't want to spend hundreds in shipping charges to and from the heart of the USA?
Old 8th August 2015, 11:43 AM   #5
SY's Avatar
Try contacting anatech (a member/mod here). He's in Georgetown and is the best there is for repairs.
“The short explanation is always dull. It generally includes the word ‘just.’ The explanation only becomes beautiful when you immerse yourself in every nuance.”
Old 8th August 2015, 12:14 PM   #6
us1070 is offline us1070  India
To fix you will need to find and replace
You will need to find faults:
1.Shorted Transistors
2.Infinity resistance Resistor
3.Shorted Resistors
3.Blown/bulging Capacitor
Also check the output transistors if they are fine
Old 9th August 2015, 11:50 PM   #7
Thanks for all the advice and tips folks!
I'll try to contact anatech, and shall update the thread when I make some progress.
Cheers!
Garry.
Old 12th August 2015, 02:38 AM   #8
anatech is offline anatech  Canada
anatech's Avatar
Hi Garry,
You have mail. Yes it is repairable, yes the board is damaged and requires a little work as djk mentioned. There are other problems that I'll look after as well so they don't bite you later on. Costs will depend on what we find once in there, but I will let you know.
SY, thank you for those kind words. Its appreciated.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 13th August 2015, 04:55 PM   #9
east electronics's Avatar
3.Shorted Resistors
3.Shorted Resistors
well in no case resistors will short ...They will drift or go open ...
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Adcom GFA-555 eelekim Pass Labs 2 14th May 2009 03:42 PM
Gfa 555 rocketmannj Solid State 0 13th October 2008 10:50 PM
GFA-555 transformer help ben62670 Power Supplies 6 20th May 2008 02:42 AM
FS:Adcom GFA 555 and GFA 5300 trusound Swap Meet 0 13th December 2005 05:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
