Hello,
After servicing a KAV300i, I need to set the bias current of the power stage. Amplifier works fine but heatskins are (very) hot even at low power.
I can't find any information about the value of this current on the Web, neither service manual of this amplifier.
If anybody has a Krell KAV300i, it would be nice to mesure the tension between TP2 and TP3 (left channel) and TP5-TP6 (right channel), with no modulation and ten minutes after switch it on ! Bias is changing with power level, so no modulation at the input during mesurement !
Thanks a lot for helping.
Best regards.
2N6658
Best regards.
2N6658
