Best amp with 2sk1058 - diyAudio
Old 4th August 2015, 06:03 PM   #1
umut1001's Avatar
Default Best amp with 2sk1058
Hı. I am looking fr Th best amp around 40w rms or over made with 2sk1058 and 2sj162.It is because I like the sound f 2sk1058 lateral mosfet. I think it has a Magic. I bought a kit but my friend told me that it is clone f Goldmund and needs one more driver stage
Here is the kit
M1 mos FET Stereo 70W 70W 2SK1058 J62 Kit WLX 8 | eBay
Do you know a better circuit ?What is the best i can build.It can be class aab. I am not looking for a class a amp. Thanks and best regards
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components
Old 4th August 2015, 06:16 PM   #2
jacques antoine's Avatar
Rod Elliott's P101
Old 4th August 2015, 06:20 PM   #3
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
I suggest Goldmund Mimesis clone.
Max.
Old 4th August 2015, 06:42 PM   #4
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
Mine, which is what I am listening to now.
My MOSFET amplifier designed for music.
Installing and using LTspice. From beginner to advanced.
Old 5th August 2015, 12:35 AM   #5
RSK is offline RSK  Malaysia
Default Mooly's amp
I suggest this also.
Very easy to build and sounds amazing.
Old 5th August 2015, 12:42 AM   #6
meanman1964's Avatar
Look at the VSSA or the FetZilla (have some FetZilla boards left)
Old 5th August 2015, 12:53 AM   #7
marsupialx's Avatar
Check out Cubie 3. I have built Cubie 2, and juma reports Cubie 3 retains sonic attributes with higher power. Cubie 2 is among the very best amps I have had the pleasure to hear.
Old 5th August 2015, 02:09 AM   #8
Bare is offline Bare  Canada
VSSA
Old 6th August 2015, 07:21 AM   #9
umut1001's Avatar
Hı Moly.I am sure it sounds very good.Why have not you used low noise transistors like bc560c and bc550c ? Or Japanese equalivents? Can circuit be upgraded this way ? Thank you and best regards
Old 6th August 2015, 08:09 AM   #10
Mooly's Avatar
No real reason, the devices used were to hand. The 2SA872A (obsolete now) would probably be one device that I might have considered, but I think you will find (in practice) that any semiconductor changes have a very minimal impact on noise performance for this design... mainly because the other component values and general topology are the dominant factors.
Used with fairly sensitive B&W703's, noise is only apparent with your ear a cm or so on axis from the tweeter.
2sk1058 mosfet amp tubem Solid State 37 1st May 2014 11:57 PM
2sk1058 mosfet amp tubem Introductions 1 20th July 2010 02:46 AM
Cheap 2sk1058 & 2sj162 rckbrwn Parts 5 9th October 2009 01:30 AM
Replacement for 2SK1058&2SJ162 thelordash Solid State 36 22nd September 2008 09:31 AM
is it necessary to match 2sj162&2sk1058 umut1001 Solid State 26 14th November 2007 07:49 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
