Pegeant AV-126-TR Projector - diyAudio
Old 24th July 2015, 11:33 AM   #1
Default Pegeant AV-126-TR Projector
HI,
I am working on the audio circuit of this very, very old projector. My concern are the 2 power transistors. They are 2N307, a TO-3 germanium power transistors. When tested base to emitter and base to collector forward bias, they read about 10 ohms. When tested reverse bias, they read about 3K ohms. When tested collector to emitter both ways, they read about 600 ohms. Are these low resistance readings normal for germanium power transistor or are the transistors leaky. I am not familiar with germanium power transistors. I am also unable to find a suitable replacement. Can someone please help.
Carlos
Old 24th July 2015, 12:37 PM   #2
JonSnell Electronic's Avatar
That sounds about right to me. They are normally slightly leaky with a 0.4V junction voltage unlike 0.7V for silicon.
Support for Fender, Marshall and all Valve Equipment including Audio Innovations, Quad and Leak. www.jonsnell.co.uk
Old 24th July 2015, 12:56 PM   #3
Thanks, JonSnell, I will try out the transistors and let you know.
Carlos
Old 25th July 2015, 11:36 AM   #4
Carlos
I put in the transistors and tried. There is sound but distorted. It cannot be the capacitors as I have changed all the capacitors on the board. The only problem is that the values are not exact. Like I replaced the 60uf with 56uf, 75uf with 68uf, 25uf with 22uf and so on, all within the 20% range. I have tested the small transistor and resistors as well and they are OK. One of the power transistor seems to get hotter and faster than the other. These PNP transistors are totally obsolete. Can I use a silicon PNP transistor as a replacement. Will the circuit work. Please advice.
Carlos
TO-126 transistor equivalent EchoWars Solid State 20 9th June 2014 07:58 AM
fe 126 mcr483 Full Range 13 9th November 2010 06:46 PM
fostex 126 done (2) ... now ??? DimZ Full Range 22 27th February 2009 06:57 PM
Thorens 126 parts dod996 Analogue Source 0 17th January 2008 01:05 PM
Carver AV-405/AV-505 mains voltage rt_jensen Solid State 0 25th April 2005 03:03 AM
Copyright 1999-2017 diyAudio
