Revisiting some "old" ideas from 1970's - IPS, OPS
I finally managed to come up with a layout for one channel of the CFA/VFA combination design. This will still mount flat nicely on a 6" x 12" heatsink. One more channel to go.
The design has to suit EITHER device combination.
Rarely can one just swap devices.
This is actually right. In most cases, the amp is designed for particular output devices, including compensation scheme. So, if someone gust swaps the devices, the whole thing may start ringing/oscillating.
For this particular case - MJL21194/93 will be ok, although when using them in such high-speed designs there's always some risk of trouble at high frequencies.
