Revisiting some "old" ideas from 1970's - IPS, OPS
Old 23rd July 2015, 07:07 PM   #21
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Arrow Update!
I have slightly updated the schematic and Jeff has designed a great layout for the beast. There is a trimmer for DC offset adjustment now.
R23 = 130R, VAS current = 5.5 mA, good for Slewmasters.
R23 = 47R, VAS current = 15mA, good for driving the MOSFETs directly (e.g. Tubsumo).
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 23rd July 2015, 07:15 PM   #22
vzaichenko's Avatar
Originally Posted by ostripper View Post
You have 5 comp. caps ? Lead /lag , miller , and a shunt ! How did you arrive at these ?
BTW , a very interesting "blameless" -mutant. I like the decoupled low voltage input and overload clamp.
OS
Each comp cap is responsible for particular part of the curve At the same time - most of them are rather small.
Key topology specialty - a "vertical" differential cascade, doing a lot of good things at once. The whole thing is going to be pretty fast for VFA
http://vzaudio.com/
Old 23rd July 2015, 07:42 PM   #23
vzaichenko's Avatar
Originally Posted by still4given View Post
Funny that we have to look back to the 70's to find really good amps. I'd say that is because stereos "mattered" back then. Having a great stereo was a status symbol and folks were willing to pay good money to impress their friends. Today they need to stuff 6 channels into a small box that will fit on a shelf under their flat screen.
How I remember going to the audio store and listening to Emerson, Lake and Palmer through a huge set of speakers and monster amps. Bass you could feel and mids and highs that seemed to come from every corner of the room. The store was filled with young men dreaming of owning that perfect "system". Those were the days! Great memories.
Yeah - those were the days ))
Well, in the end of the century there were some sort of "no compromise" designs as well. Just came across Sony TA-NR1 the other day. Imagine two Slewmaster power sections with 5 pairs of MT200 Sankens each, connected in parallel (PD+ to PD+, ND- to ND-, output to output), and biased to class A. This is just one channel Huge power supply. 47.5kg of metal. Monumental engineering
http://vzaudio.com/
Old 23rd July 2015, 07:48 PM   #24
jwilhelm is offline jwilhelm  Canada
Those were the days when Sony's car audio was excellent as well. The old C90 was an incredible cd player. The tuners weren't very good though. 4 years later their flagship was worth $400 and sold in big box stores. That's a huge shift in engineering in a short time.
Old 23rd July 2015, 08:08 PM   #25
still4given is offline still4given  United States
still4given's Avatar
Are you only planning to do a SMD version? I was hoping for a single sided "etchable" version.
Old 23rd July 2015, 08:14 PM   #26
There are more coming. I'm going to do smd and through hole versions of both designs.
Old 23rd July 2015, 08:40 PM   #27
Can you double check the orientation of the VAS transistors? I think the 3D model is backwards in Diptrace. I think I have them installed correctly(ECB) but Diptrace is showing the metal side out.
Old 23rd July 2015, 08:42 PM   #28
vzaichenko's Avatar
Yes, I have noticed that - 3D model is wrong. Your orientation is good.
http://vzaudio.com/
Old 23rd July 2015, 08:47 PM   #29
That might explain some messed up orientation in past designs.
Old 23rd July 2015, 11:28 PM   #30
Here's CDC-VFA-Boot in SMD.
Revisiting some "old" ideas from 1970's - IPS, OPSHide this!Advertise here!
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
Separate IPS and OPS boards? Neutrality Solid State 5 18th June 2011 08:40 AM
B200 in a OB with a added "twist". Ideas needed. Mattias S Full Range 4 29th November 2010 06:35 PM
Looking for a 1970"s Marshall Mark II schematic.. Minion Instruments and Amps 2 1st February 2009 04:48 PM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 09:02 AM
