Revisiting some "old" ideas from 1970's - IPS, OPS
Old 5th February 2018, 04:50 AM   #2461
pinnocchio is online now pinnocchio  Canada
pinnocchio's Avatar
Does Q10 and Q13 of Tubsumo IPS require heatsinking?
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 5th February 2018, 10:45 AM   #2462
jwilhelm is offline jwilhelm  Canada
Do
Yes they do. A small clip on heat sink works fine there.
https://www.vzaudio.com/
Old 5th February 2018, 04:01 PM   #2463
pinnocchio's Avatar
ok, thanks
Do
Old 9th February 2018, 04:23 AM   #2464
pinnocchio's Avatar
My Toroidy transformer is finally on its way home, yesssss!!!!
Can't wait to get this rollin'
Do
Old 9th February 2018, 10:38 AM   #2465
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Cool Coming closer to powering the whole thing on
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 10th February 2018, 05:30 PM   #2466
filenet is offline filenet
Good work Do...but i recently found that if you don`t have a CNC machine at your disposal your project `stinks`.
Also i found that thick film smd resistors `stink` you should revert to THT. I wander what those bastards that use carbon composition resistors think. Maybe that distortion figures are not so important as long as they are low, but the harmonic profile, this is good engineering.
So i wonder... where is the joy of building an amp?
Old 10th February 2018, 05:56 PM   #2467
pinnocchio's Avatar
Hi filenet,
I've been using many different tools to work on aluminum and I can do some very nice work with them without using a CNC. You just need to be very patient. It also require much more work but I'm not in a rush.
All my SMD resistors are Thin Film only which are exactly the same as TH Metal Film. Don't know much about carbon resistors aside knowing that my tube fan friends use them in their tube amplifiers and it usually sound really good. I guess its all about design but also, tube amplifiers usually have more distorsion.
Honestly, I love building amplifiers, I only hate doing all the cabling since I'm a little obsessed with having everything neat and tidy, it takes me so much time that I sometimes hate it...
All the best!
Do
Old 10th February 2018, 06:04 PM   #2468
I am sure that you like building amps, this it can be seen. I am just checking the latest trends
Old 10th February 2018, 06:34 PM   #2469
pinnocchio's Avatar
I totally get what you mean though. Many times someone will build something but it will never be what he/she really wanted to achieve, sound-wise and look-wise and at this point it would have been much easier to buy something from the commercial side, that you know what to expect.
My first build over ten years ago (I was buying commercial only before) was made of MDF and sounded good but was really fugly, definitely not WAF, although my wife has a high tolerance, I did not push my luck for too long..
Ciao!
Do
Old 10th February 2018, 06:44 PM   #2470
Successful builds take as much time planning as it does building. I'm fortunate to have 3D CAD software and a machine shop. It's rough building from scratch without a milling machine!
Revisiting some "old" ideas from 1970's - IPS, OPSHide this!Advertise here!
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
Separate IPS and OPS boards? Neutrality Solid State 5 18th June 2011 08:40 AM
B200 in a OB with a added "twist". Ideas needed. Mattias S Full Range 4 29th November 2010 06:35 PM
Looking for a 1970"s Marshall Mark II schematic.. Minion Instruments and Amps 2 1st February 2009 04:48 PM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 09:02 AM
