Revisiting some "old" ideas from 1970's - IPS, OPS
Old 9th November 2017, 06:19 PM   #2291
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
For zeroing out the offset - adjust the value of R9 - if your trimmer, being at the lowest offset position, is showing zero value - decrease R9. If the trimmer shows its maximum value - increase R9.
Oscillation - possible. I always have an oscilloscope connected to the output of the amp on a test bench - you can see what's going on right away
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 9th November 2017, 06:24 PM   #2292
thimios is offline thimios  Greece
Originally Posted by jwilhelm View Post
it would be better to work with the input in standalone mode until it's debugged, then figure out the output board issue. Doe DC offset move at all when adjusting R8? if so which way is the pot stopping at? Max or minimum? R9 needs to be changed sometimes. Valery says this is due to different forward voltage in different LEDs.
The output board haven't any issue as work well using all other IPS.
The offset trimmer isn't possible to zero the offset and i don't believe that do the job well.
Ok,i will reinstall the IPS using lamp,protective resistors and oscilloscope looking for a possible oscillations.
The offset problem is another story.
Old 9th November 2017, 06:57 PM   #2293
jwilhelm is offline jwilhelm  Canada
I have finally got TubSuMo squeezed onto an input board for the NS-OPS series amps.
https://www.vzaudio.com/
Old 9th November 2017, 07:01 PM   #2294
Revisiting some "old" ideas from 1970's - IPS, OPS-tubsumo-jpg
Good!
Another IPS to the family!
Old 10th November 2017, 05:04 PM   #2295
Revisiting some "old" ideas from 1970's - IPS, OPS-dsc09458-jpg
Testing the A-X Deluxe as stand alone IPS.
The offset problem solved using 390R//1K.
As i can't see other problem here i'm afraid that this IPS oscillate when connected to OPS.
Old 10th November 2017, 06:35 PM   #2296
vzaichenko's Avatar
Looking pretty good.
You can add 47pF in parallel with R22, R23 for a safer test with OPS.
http://vzaudio.com/
Old 11th November 2017, 04:56 AM   #2297
Default A-X Deluxe
Revisiting some "old" ideas from 1970's - IPS, OPS-dsc09461-jpg
Arrested!
Amplifier oscillate at 56.5Mhz,see picture.
This measured without any load when input is open.
Old 11th November 2017, 05:44 AM   #2298
vzaichenko's Avatar
OK - 450mV - not too "evil" )
No additional capacitors, mentioned in my previous post, right?
http://vzaudio.com/
Old 11th November 2017, 05:49 AM   #2299
Right,47pf// to R22 R23 not added yet.BUT the lamp in series with transformer primary side and the protective resistors(instead of fuses) are in circuit.
I see 7v d.c on 18R/10W resistors.
Old 14th November 2017, 07:42 AM   #2300
Default AX-Deluxe+NS
Revisiting some "old" ideas from 1970's - IPS, OPS-dsc09478-jpg
33pf trimmer// R22,R23.
This way amplifier is stable but i see a little warm zobel resistor even with sinusoidal at clipping levels.
Test conditions:+/-50V.
75.000uf/rail
22mA/Pair idle current.
R dummy=6R
980mV input, 26.6V RMS/6R=118W RMS out,or 176W/4R.Just before clipping.
-3db,2.5Hz-300Khz.
Revisiting some "old" ideas from 1970's - IPS, OPSHide this!Advertise here!
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
Separate IPS and OPS boards? Neutrality Solid State 5 18th June 2011 08:40 AM
B200 in a OB with a added "twist". Ideas needed. Mattias S Full Range 4 29th November 2010 06:35 PM
Looking for a 1970"s Marshall Mark II schematic.. Minion Instruments and Amps 2 1st February 2009 04:48 PM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 09:02 AM
