Revisiting some "old" ideas from 1970's - IPS, OPS
Old 19th June 2017, 01:21 PM   #2141
carlmart is offline carlmart  Brazil
Originally Posted by vzaichenko View Post
Sorry - one more pretty cool IPS module
I just came across M-02 / MX-100 front-end and realized it's designed based on the same principles I like to use these days ("Bravo Luxman engineers!"). Besides the jFET input pair (transconductance stage), all the rest of the circuit is controlled purely by current, resulting in rather high slew rate (around 100V/uS with OPS in place), low distortion with excellent profile, low phase shift at 20KHz and excellent stability margins with very light compensation. As a cool bonus - perfect clipping.
My version of the topology uses mostly TO-126 devices - most of them dissipate 150...170mW, except LTP's tail (Q3) - it runs at 450mW.
Besides BF862, 2SK170 jFETs can be used in the input pair (layout needs to be updated in this case).
Luxfront can be used with any OPS, published in this thread.
It's also compatible with Slewmaster OPS boards.
Diy-friendly layout for etching is attached (PDF).
Do you mean a something like this combo?
Interesting NFB arrangement Luxman used, as it allowed using a film cap.
Old 24th June 2017, 03:54 PM   #2142
Kay Pirinha is offline Kay Pirinha  Germany
Hi Valery,
is it possible to add a BJT output stage to your Lichtstark IPS design? I'm about to rework two Klein & Hummel power amplifier modules from an ES-707 integrated amp thaw show some major design flaws (see schematics from elektrotanya). Instead of converting them from quasi to true complementary outputs, I'm now opting for the following: As their physical construction (enclosure parts, heat sinks...) resticts me to two pairs of TO-3 units each, I'm considering your Lichtstark, followed by two ONS »Perforated Emitter« MJ15025/26 pairs - the fastest TO-3 devices I know in this power specs range. As the completed build might be used in rather rough environments, an IV limiter is a must. On the other hand the PSU will be a chain of four very cheap 24V/2.5A SMPS per channel to get ±48 Vdc rails. I've yet tested them, they can be overloaded to 3A at least for half an hour. But somewhere surely there's a current limitation. Do I need a current limiter within the amp design despite of that?
Best regards!
Old 24th June 2017, 05:38 PM   #2143
jwilhelm is online now jwilhelm  Canada
Originally Posted by Kay Pirinha View Post
Hi Valery,
Best regards!
How much space do you have to work with? I have a version running with two pairs of hexfet outputs. They may be possible to convert to BJT or just run the fets. They are more robust devices and the amp sounds great as is. They are designed to run on +/-48V rails too.
We have a protection system designed to plug into these amps that will shut the amp down if current flow in the output stage exceeds SOA of the devices. Standard IV limiting often makes an amp sound bad at higher volume.
Old 24th June 2017, 06:53 PM   #2144
Your HexFETs aren't TO-3 devices, are they? As said, there's no other option than for TO-3's. I have to design my own PCBs, as their size has to match the originals, i.e. 190 x 100 mm. No further restrictions, though .
Best regards!
Old 24th June 2017, 06:56 PM   #2145
Best regards!
I misread the TO-3 part. I was thinking TO-3P.
Old 24th June 2017, 07:32 PM   #2146
This might be a neat combination with Valery's old Compact VFA output stage. I did a version of it with TO-3 outputs but never got as far as building it.
Old 26th June 2017, 02:41 PM   #2147
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
I would recommend this OPS:
1 or 2 pairs of BJT output devices
Marc has designed a very good compact layout for it.
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
VIRTUAL ZERO distortion AUDIO
Old 26th June 2017, 03:35 PM   #2148
Hi Valery,
ss said before, I'm restricted to TO-3 power devices. Can I use ONS MJ15025/26 instead of these Sanken transistors?
Best regards!
Old 26th June 2017, 04:12 PM   #2149
vzaichenko's Avatar
Hi Valery,
Best regards!
OK, they will work, but be careful with HF signals - I would tune the input RC filter to some 50KHz roll-off and would not try to pass anything above that frequency through the amplifier - there's danger of rail-to-rail current shoot-through - those transistors close much slower that RET devices, like those Sanken ones.
Old 26th June 2017, 04:14 PM   #2150
DPH is offline DPH  United States
Man, those suckers are slow, which really does hamper the amount of loop gain you can wrap around them. You'll have to change up the compensation quite a bit. Can you possibly make some aluminum adapter blocks to take the TO-3/TO-264 packages? Nothing too fancy.
Happy DIYing, Daniel
(This space is occupied by the artist formerly known as Derfnofred)
Revisiting some "old" ideas from 1970's - IPS, OPSHide this!Advertise here!
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
Separate IPS and OPS boards? Neutrality Solid State 5 18th June 2011 08:40 AM
B200 in a OB with a added "twist". Ideas needed. Mattias S Full Range 4 29th November 2010 06:35 PM
Looking for a 1970"s Marshall Mark II schematic.. Minion Instruments and Amps 2 1st February 2009 04:48 PM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 09:02 AM
Copyright ©1999-2017 diyAudio
