power amplifier with one-stage voltage amplification
"What do you think about scheme of power amplifier with one-stage voltage amplification such use in AD797?"
The AD 797 gets really good performance out of only one voltage gain stage, doesn't it?
That complementary output stage (diamond follower) is nice too, 50mA of drive!
Try this site:
http://home.kimo.com.tw/skychutw/
click on:
circuits, and then on:
Hadley 622
You should end up here:
http://home.kimo.com.tw/skychutw/Circuits/Hadley622.pdf
Update the output stage to a diamond follower and there you are: a very low distortion single voltage gain stage amplifier.
It even has the Nelson Pass 'X' feedback arrangement.
It even has the bootstrap current source the AKSA crowd likes.
One set of drivers and outputs (2 each of MJE15030/31 and MJ21193/94) should give 200W/4R
