Adcom 5400: using lower capacitance caps - diyAudio
Old 9th July 2015, 05:41 AM   #1
Default Adcom 5400: using lower capacitance caps
It's time for me to recap my Adcom 5400, and a respected modder and audio engineer recommended that I replace the 12000uf 63v PS caps with 10000uf 63v caps. The reason for this is that it would allow me to use his preferred caps--Mundorf. They don't make a 12kuf version.
For the sanity check, do you all think this is a good idea, if my main goal is improved sonics?
Oh yeah, one more detail: The amp won't be driven very hard. I'm only using it to drive the mids/tweets in a biamp configuration.
Thanks!
Old 9th July 2015, 07:51 AM   #2
Did it Himself
richie00boy's Avatar
I think it is a bad idea. Just fit good quality caps of the correct value or a little more, never less. There is absolutely nothing wrong with the major brands like Nichicon, Panasonic or Rubycon. They probably cost less and have better specs as a bonus.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 9th July 2015, 08:09 AM   #3
Michael Bean's Avatar
+1
Mike
Old 9th July 2015, 08:13 AM   #4
sajti is online now sajti  Hungary
Now I'm going to the opposite side:
I don't think, that this reduction makes any kind of porblem. Maybe it can reduce the bass quality somwhat, but it's out of question, as You wrote.
Just one remark: It will be hard to predict, if the sound quality will be better, or not.
Sajti
Old 9th July 2015, 08:38 AM   #5
Hmm. Yeah, it would be weird if taking this person's advice would mess it up, given his reputation. But it makes me a bit uncomfortable, if for no other reason that I would have to defend the decision if I were to try to resell it.
I just found that Mundorf does make a 15kuf cap, but unfortunately it has a 5mm bigger diameter. It's pretty tight in there--not sure if it will fit.
15,000µF / 63VDC, MLytic® Audio Grade MLGO (Glue-On 2 Pin), 35mmD x 60mmH
MUNDORF M-Lytic AG Series MLGO+ (Glue-On) & MLSI+ (Snap-In) 2-Pole Electrolytic Capacitors
Mundorf MLytic AG MLGO 15000uF 63VDC, Sonic Craft
Here's the puzzling part--almost nobody seems to carry the cap in this value, and Mundorf's spec sheet skips from 10k to 22k. (http://www.partsconnexion.com/prod_pdf/mund_ag.pdf)
Old 9th July 2015, 09:12 AM   #6
DF96 is online now DF96  England
Electrically, replacing 12mF with 10mF will make almost no difference - very slight increase in hum. However, with the typical electrolytic tolerance range you could be increasing capacitance by a little or reducing it by more!
Replacing Brand X by Brand Y caps will make no difference, assuming both are competently made.
So my conclusion is that this is a bad idea if your aim is "improved sonics". This is because it costs you money to get nowhere. On the other hand, if you would like the warm glow of knowing (and telling your friends?) that you have used Brand Y caps as an 'upgrade' to your amp then go ahead.
Old 9th July 2015, 09:15 AM   #7
There are some possibilities to choose:
15000uF Aluminium Electrolytic Capacitors | Mouser
Sajti
Old 9th July 2015, 02:13 PM   #8
Adcom gfa-5400 mods?
Old 9th July 2015, 04:11 PM   #9
Welcome is offline Welcome  France
Welcome's Avatar
Whoever recommended the Mundorf caps has just invalidated their reputability and thus the advice can and should be dismissed as nonsense. Stick with reputable capacitors from honest, real manufacturers. Mundorf is a snake oil scam company.
Some questions on an Adcom 5400 beanbag Pass Labs 31 14th June 2015 07:12 PM
Adcom GFA 5400 questions beanbag Solid State 1 16th May 2015 05:47 PM
Adcom GFA-5400 / Help please... luicas Solid State 5 6th May 2015 07:25 PM
Adcom 5400 schematic needed ctong Solid State 1 4th June 2013 08:25 PM
Adcom GFA-5400 kenscott30 Swap Meet 0 4th December 2005 06:08 AM
Copyright ©1999-2017 diyAudio
