Need advice on Power supply - diyAudio
Old 7th July 2015, 01:33 PM   #1
Default Need advice on Power supply
I have a small phono stage, that is a bit noisy.
I tried it direct with two 9V batteries, and it got better alot.
I am intending to power it up with five or six Li-Po rechargeable mobile phone batteries built into the the same enclosure.
The device has 24V DC wall charger type feeding into it, which goes into some smoothing and an LM317 regulator down to 20V.
The batteries (6 of them ) give 4.1V on full charge to 3.7V nominal.
here is the question:
should I keep the LM317 in circuit to get my steady 20V or should I not ?
Old 7th July 2015, 02:00 PM   #2
Did it Himself
richie00boy's Avatar
What kind of noise are you getting? Hum?
Lipos require a bit of sophistication in the charging (and protection against over discharge) or you are likely to set them on fire.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 7th July 2015, 02:10 PM   #3
No hum, background hash.
I should be able to charge them safely ( I got charger circuits).
i'll explain more, shall I.
Would the LM317 introduce any noise of its own, even if supplied by batteries?
if not, I can leave it in.
If it it does, I have to rearrange my circuit to work with 22V nominal.
Old 7th July 2015, 02:12 PM   #4
DF96 is offline DF96  England
You could leave NiCads on trickle charge quite safely for days. Modern rechargeable cells are more fussy, so fires or explosions are easier to produce. I would have thought that about the worse way to do it (unless you want explosions) is with a constant voltage charger. As a general rule, anything containing lithium needs to be handled with care.
Old 7th July 2015, 02:16 PM   #5
one does not need light weight for a phone pre-amp.
That removes the ONLY advantage of lithium batteries.
Use sealed lead acid or nicad.
But a reasonably assembled lm317 will be quiet enough for most users.
Batteries may not give any improvement.
An ultra low noise PSU should improve the phono performance slightly.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 7th July 2015, 02:17 PM   #6
Did it Himself
I am a little surprised you experienced a noise problem, usually it is hum. The LM317 should be fine to leave in circuit, when it can no longer regulate due to lack of headroom, the output just follows the input. You could always try it direct to batteries though.
Old 7th July 2015, 03:05 PM   #7
OK so far everybody is at fire risk assessment!
Let us assume I know what I am doing regarding safe handling and charging of my batteries.
the question remains,
1- does leaving the LM317 in circuit have any other benefits other than a constant voltage?
2- does leaving the LM317 in circuit have any disadvantages, noise or otherwise (compared to direct battery and a large cap.) ?
("should be OK for most users" is not helpful, if it was, I wouldn't have needed to open the device in the first place)
ofcourse I could try every scenario out, and discover it practically (the hard way),
but since I am lazy and value the opinions of most members here, I thought I ask!
Old 7th July 2015, 03:11 PM   #8
infinia is offline infinia  United States
infinia's Avatar
you should concentrate on this original problem, as a new constant connected voltage battery charger may give the same problem plus added complexity or danger even.
what regulator circuit did you use originally? batteries are IMO a choice of portability or last resort.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 7th July 2015, 03:18 PM   #9
what made you assume that I have my batteries "constant connected battery charger" ??
I charge them first, remove charger and then use the device on batteries only.
To my calculation I should get over 25 hours listening on one charge.
Old 7th July 2015, 03:28 PM   #10
infinia's Avatar
so do ever think you might be demanding answers to the wrong questions?
Power supply advice needed mannish boy Tubes / Valves 9 23rd October 2013 08:49 PM
please advice capacitor for my power supply kwm488 Solid State 8 1st September 2012 07:43 AM
need power supply advice for future power amp project. boricuaso Chip Amps 13 6th February 2008 02:24 PM
Some advice on this power supply Richard Tubes / Valves 11 23rd June 2006 05:21 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
