Large offset and large differential input to input pairs... but amp works..?
Old 4th July 2015, 06:11 AM   #1
Fusion916 is offline Fusion916  United States
Default Large offset and large differential input to input pairs... but amp works..?
Have a strange problem I have no encountered before. Here are the symptoms.
Amp works fine, I get a clean signal output, under load, is stable (clean square wave no overshoot). But there is something going on with the LTP offset and amp offset.
Speaker out (vout) offset is ~90mV.
Feedback input is ~90mV
Signal Input is +50mV (???????)
Closed loop gain is fine (25V/V vs 31V/V from feedback ratio), so I don't think the open loop gain is as bad as the differenital input to the LTP suggests. Somehow it seems there is some kind of offset going. I took a look at some the bias voltages and everything seems to look ok EXCEPT each input to the LTP.
Where to debug next?
Old 4th July 2015, 06:26 AM   #2
Alan0354 is offline Alan0354  United States
Banned
90mV at the output is not the end of the world!!! If you have complementary LTP IPS, it's not that surprising.
Old 4th July 2015, 06:29 AM   #3
Yes, it doesn't kill any audio quality or anything, but I still want to understand it. I've built many amps with LTP input stage and I usually get an offset of 1-10mV. Ive never seen 90mV and I have never seen a LTP offset this large before, which leads me to believe there is some misconnection, broken part, or broken trace on the PCB, but I can't find it so far.
Old 4th July 2015, 08:32 AM   #4
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
A schematic would help but anything up to 150mV is OK. This is usually caused by a misbalance on the differetial matched pair input transistors hfe. If you are worried about this minor issue, swop them over and read the difference.
No idea what "LTP" or "IPS" stands for. Don't do text speak.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 4th July 2015, 09:01 AM   #5
I was just dicking around in spice playing with mismatched emitter resistor values and yes mismatching values does create the exact effect I am seeing, which would translate into mismatched bjt re values...
Maybe ive just lucked out and never built and amp with LTP transistors that never mismatched this much.
Old 4th July 2015, 09:05 AM   #6
currentflow is offline currentflow  United Kingdom
LTP = Long-tailed pair and refers to a differential amplifier.
See Figure 2 here: https://en.wikipedia.org/wiki/Differential_amplifier
IPS = InPut Stage.
currentflow
Old 4th July 2015, 10:00 AM   #7
IPS = InPut Stage.
Thanks for the deciphering.
(I still send texts in English!)
Old 4th July 2015, 09:02 PM   #8
bwaslo is offline bwaslo  United States
bwaslo's Avatar
Is it by chance a late 70s vintage Hafler DH200? I ran into and fixed a number of those, with those same symptoms, back in the day. The high voltage diff pair transistors went leaky. Fixes were to replace those (all 4 in each channel) or (more difficult) change the stage to a cascode.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Large offset and large differential input to input pairs... but amp works..?Hide this!Advertise here!
Why such a large input series resistor? ammel68 Headphone Systems 8 26th September 2014 02:23 AM
Adding a third input to a differential input stage? maudio Solid State 15 11th October 2006 02:16 AM
Input Differential Pairs and Zetex Transistors EchoWars Solid State 6 19th June 2003 01:41 PM
Copyright ©1999-2017 diyAudio
