Technics SU-V3 negative voltage at output!!!
Old 2nd July 2015, 05:01 PM   #1
reji is offline reji  India
Default Technics SU-V3 negative voltage at output!!!
I got this amp from a friend which is already tried to repair by someone else and still have problem with one channel. Negative voltage is showing at the output stage in one channel and other channel is quite normal. I checked the output transistors and driver transistors, all shows good. When I removed the Q319(c2631) there is no negative voltage at the output. 2SC2631, 2SA1123,2SA992 and 2SK109 is not available here in local market. Only 2SA1015 and 2SC1845 is available here. Anyone know substitute for 2SC2631,2SA1123 and 2SA992? Please help !!!
Old 3rd July 2015, 05:37 AM   #2
Any substitute in MPSA** or 2N**** for 2SC2631,2SA1123 ???
Technics SU-V3 negative voltage at output!!!Hide this!Advertise here!
Technics SU-V4 idle current and clamp voltage adjustment confusion Welcome Solid State 2 16th November 2013 01:16 PM
Panasonic SU-2700 Repair (Otherwise known as the Technics SU Z1) MChandler Solid State 22 11th April 2013 07:25 AM
Is STK2038B the output stage for Technics SU-Z55? AX816 Chip Amps 5 14th March 2011 05:08 PM
Technics SU-8077 nev1956 Parts 2 20th November 2007 03:56 PM
