qinpu a3 doesn't relay click - diyAudio
Old 30th June 2015, 06:00 PM   #1
hewo is offline hewo  United States
Default qinpu a3 doesn't relay click
Can't get relay to click, can't get factory assist, but examination reveals as follows
1. Tranny secondaries all good output
2. Replaced all zeners, tubes, poweramp ic's both, all five 9014's, single d667, and single 7806
3.one of the two 9.1 zener is not producing 9.1, dunno why, maybe it engages after relay clicks?
4. Tubes heaters alive
5. Twin blue led's blink forever, and 7806 fin gets too hot, maybe junk new 7806?
6. Poweramp chips called 1875, five legged.
Can't obtain any schematic
Pl assist restore operability
Old 1st July 2015, 05:04 AM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi hewo,
Can you provide any history as to what happened to the amplifier? Can you at least take a couple pictures of the circuits?
Have you looked up the datasheet for the 1875 power amp chips? They should provide a close schematic to that stage of your amplifier.
Replacing stuff without a good idea of the problem can easily create more problems that need to be fixed. You should start by getting some idea of how the circuit works, just a general idea at least. Go from there.
So, tell us what conditions would keep the amplifier in protect mode. From there you can check for those conditions.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 1st July 2015, 05:48 PM   #3
I'll get some cellphone pics of the mobo both sides, 1875 app shts too if avail, client said just keeps flashing doesn't amp anymore. Qinpu abandoned me once disassemble pics emailed, their request, for legitimacy proceed.
Old 1st July 2015, 06:22 PM   #4
anatech's Avatar
Hi hewo,
It sounds like you are more at home with fixing computers. This is an entirely different world compared to computer service.
Look up LM1875. That will give you the information on that section.
Client. Are you repairing this as a business?
Quipu was talking to you at some point in time I guess. But the way you post is difficult for me to follow. Can you please revert to normal conversational grammar? So the pictures that Quipu requested from you, can you post them here, and what was the reason Quipu requested the pictures? I want to get a picture of the situation. This amplifier sounds like a hybrid signal tube and IC output thing. In the circuitry you probably have some high voltage circuits as well as the normal low voltage - higher current solid state levels.
Things that might help are voltage readings from the power supplies, voltages around the tube(s) as well as some voltage readings from the speaker relay contacts. This is in addition to pictures you may have.
-Chris
Old 1st July 2015, 06:33 PM   #5
anatech's Avatar
Hi hewo,
A little look on Google tells me that this is a $200 (street price) headphone amplifier. The LM1875 is running with supply voltages around +/- 15 VDC, well below the maximum of +/- 30 VDC. The chip should be reliable. It uses a pair of Russian tubes as signal amplifiers. The plate voltage would be interesting to find out.
Are the heaters working? The tubes should feel warm, you might be able to see the glow from the heaters on about a 45 angle down from the top.
-Chris
Old 1st July 2015, 08:17 PM   #6
Yup, I've been sucked in after success prior repairs this forum, so outsiders dump their gear onto me to repair, kinda word of mouth. This qinpu problem is likely a dead feed for permissivity conglomerate prereq's prior to firing coil relay.
I chk'k the tranny secondaries ok, downstrm dc a bit confusing without schematic.
Factory engr contact scared off? Pics were only mobo and appurtenances disassembled complete, not closeup as you will be getting.
Resistors are all 1/8w except coil feed dc 1/4w 220 ohm
Pl stndby pics, I have disease, encephalopathy, succinct writing, please bear with me
Old 2nd July 2015, 02:49 AM   #7
anatech's Avatar
Hi hewo,
I'm very sorry to hear you have this problem. Would you mind if I asked which type? You do not have to answer if it makes you the least bit uncomfortable.
This may have scared your factory contact off. We'll do our best to understand your meaning in posts.
The pictures might be helpful. By chance, did you have a chance to measure the supply voltages and the DC offset voltages?
-Chris
Old 2nd July 2015, 03:09 AM   #8
Default qinpu_pics
this site wont take cellphone pics, too Mb biggy, so goto ftp dwnld:
<removed information at member's request>
it's easy fix, some prereq not permissible, so conglomerate prereq's not met, so logic analog circuit refuses activate relay coil excite, right?
gotta restore china 7806 since ebay 7806 finning too hot
yup always heaters russian tube replcmnts glowing 6dc volts by regulator
remember one of two zener 9.1V does not have 9.1vdc across it, why, relay unengaged yet?, or fault lies around this sector circuitry
remember ALL zeners replaced, all 9014's replaced, D667 replaced, IC 1875's pair replaced, tubes replaced by russia tubes, 7806 replaced, cheap stuff, still no go
also notice umbillicaled 1875"s via flex ribbon (stolen from scrap ide cable), factory was rightangled rigid headers, very unfriendly, btw, mica TO-220 insulatory crappy, keeps delaminating as mineral sheet layers ultra thin, gotta utilize grey fabric weave heat silicone transfer pads, no thermal grease legacy compound.
so why was qinpu scared off?
Originally Posted by anatech View Post
Hi hewo,
-Chris
Old 2nd July 2015, 03:13 AM   #9
Default ftp picture downloads expiration warning
my posted ftp download expires (deleted) in few days i believe, so, get it before it vanishes, qinpu_pics.pdf
Hi hewo,
-Chris
Old 2nd July 2015, 03:19 AM   #10
anatech's Avatar
Hi hewo,
I have your PDF file now. Would you like me to delete your account information from your post? I would highly recommend this.
-Chris
lp-2020a+ with no sound, no relay click, no nothing leosep Chip Amps 12 1st February 2014 03:47 PM
Kenwood KM 105 does not click safety relay srinath Solid State 2 8th January 2014 09:47 PM
lepai lp-2020a+ doesn't turn on, no relay click thebestofall007 Class D 6 6th January 2013 12:45 AM
Memphis MC1000D relay doesn't click ComputerJLT Car Audio 8 24th February 2012 01:32 AM
Please help with aleph p 1.7 volume relay pops and click ostemaden Pass Labs 2 27th July 2004 03:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
