diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Preamplifier from German magazine Klang&Ton (http://www.diyaudio.com/forums/solid-state/27640-preamplifier-german-magazine-klang-ton.html)
supernet 5th February 2004 08:05 PM
2 Attachment(s)
Some time ago, Klang&Ton - German DIY speaker magazine-published a "top end" preamplifier which has an output impedance close to 0, so it should drive any cable any time.
input Z : 10 kohm
output Z : <1 ohm
signal to noise ratio : >100 dB
slew rate 9V /us
Rise falltime: <1,5 us
max output voltage : >8 V eff
What is your opinion about this preamplifier schematic??
Cybergent 5th February 2004 11:18 PM
Can you bring up the picture with better quality?
peranders 6th February 2004 05:16 AM
If the opamps are OPA134, OPA627, AD8610, LT1028 etc etc. I think it looks quite alright but can you get more info about the parts?
Werner 6th February 2004 05:54 AM
From what I can make from that schematic there is an almost total lack of care for the power supply.
peranders 6th February 2004 06:33 AM
The PS could be more serious maybe. The last thing, is it a power amp or is it only a buffer? Hard to see at the schematics.
supernet 6th February 2004 04:03 PM
Sorry about quality, because original circuit in pdf format is over 1,5 M and I could not post it here.Maybe try it with 500 zoom in Word.
This preamplifier has two stages. First is op 5532 and second is a "small amplifier" with bd 139/140 output transistors. Power supply is made with 7815/7915 regulators.
Maybe has anybody idea how to convert a large pdf file into something small indeed?
arasuk 6th November 2004 04:12 PM
preamplifier!!!!
hi,
could you post me the full Schematic of the preamplifier.
arasukumar@yahoo.com
thanks
arasuk
Elso Kwak 6th November 2004 06:50 PM
Hi supernet,
Probably a zipped Postscript file will be legible given the forum's restrictions of 800x 1200 Pixels and a maximum file size of 102400KB.
You could try Adobe Phoptoshop converting to GIF and/or resize resample with Irfanview.
Oops, I just see that Photoshop can also resize (just have it 15 minutes on my PC)
:bawling:
destroyer X 6th November 2004 07:24 PM
Cacilda Elso, Dear Elso.... are you sure?
It was 800 by 600!
Can we use 800 by 1200
Cacilda Elso!..... Regards Elso
Carlos
Elso Kwak 6th November 2004 07:36 PM
Re: Cacilda Elso, Dear Elso.... are you sure?
Originally posted by destroyer X
It was 800 by 600!
Carlos
Hi Carlos, The zipfile was 66kB.
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
