Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 21st October 2008, 03:35 AM   #21
jaycee is online now jaycee
I use Kodak "Ultima" printer paper, which is based on real gloss photographic paper. I only ever have a problem on large areas eg ground planes, and thats probably simply that the iron i use doesnt get hot enough (it was a crap one bought from a car boot sale!)
I'm using a Brother HL-1040 laser printer to do it. I started off after reading Tom Gootee's article on it The thing is, the Ultima paper works so well, that you dont need to soak it - instead you pull it off fairly carefully and the toner stays put.
Old 21st October 2008, 03:55 AM   #22
Man Of Action!
MJL21193's Avatar
Staples basic photo paper as recommended by Tom. Cheap - $30.00 for 100 sheets.
Printer is an HP 3050 laserjet.
I tried better photo paper like jaycee, and it came off much cleaner but I had to us a sheet of plain paper between it and the iron as it would stick to the back. Also took a lot more pressure because the paper is so thick.
I tried glossy magazine paper and this works but not good for fine detail. Also hard to see your print.
John
Pictures,
Pancakes, Patchwork
The main reason Santa is so jolly is because he knows where all the bad girls live. - George Carlin
Old 21st October 2008, 11:59 AM   #23
Yep, I also have to use a sheet of paper so the iron doesnt stick, and the paper isnt too cheap (still cheaper than press-n-peel! though!). It works well though so i'm reluctant to change.
I couldn't find the Staples paper here in the UK - they're not quite as big a company here.
I have debated getting some kind of cheap health grill affair and modifying it so that it has 2 flat hot plates, and will clamp the board in the middle - sort of like a laminator on steroids!
Old 21st October 2008, 12:13 PM   #24
Steerpike's Avatar
Press-n-Peel is my favourite - it works very well, but is SO expensive here.
I get good results with magazine covers - the very shiney / glossy covers (e.g., the Oprah magazine - 'borrow' it from your wife!, or the catalogues from tour companies), but large copper fill areas don't fill well; it's great for thin tracks, less than 20mil.
But large areas are easy to touch up anyway.
I soak it in sodium hydroxide solution to get the paper off before etching in ferric chloride.
You should switch the printer's seting to things like 'economy mode = off' and 'print density = max'.
Old 21st October 2008, 12:17 PM   #25
AndrewT is offline AndrewT
http://www.multimap.com/clients/brow...ch&scale=50000
regards Andrew T.
Old 21st October 2008, 07:57 PM   #26
I live near Norwich City centre, so that is miles away
I did get my first pack of Kodak Ultima paper cheap because the idiots in Partners Stationers mis-labelled it though
Thread Tools
lm3876 artwork needed ed8150 Chip Amps 0 2nd July 2006 10:12 PM
Looking for PCB artwork Wombat2 Power Supplies 3 15th December 2005 08:40 AM
LM3875 DIY artwork Technotinker Chip Amps 3 10th May 2005 04:38 PM
amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? siu sin man tho Digital Source 0 17th March 2004 01:31 PM
Page generated in 0.17960095 seconds (78.67% PHP - 21.33% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
