Emotiva DC-1 grounding mod - diyAudio
Old 25th June 2015, 10:41 PM   #1
Default Emotiva DC-1 grounding mod
Hello,
I have recently purchased an emotiva DC-1 dac/amp/preamp and when used with the headphones I bought it for there is a quiet hum audible - from what I can tell it is somewhere in the -90dBFS range or so. I'm sure with most headphones this is no issue, but I am employing it to drive in-ear monitors rated at 118dB/mW and 22Ohm impedance at 1k with wild variation across 20-20kHz due to the use of 6 balanced armatures in each ear.
From what I can tell, all competing products exhibit similar issues, my phone does not nor does the Objective 2 amp I built.
My listening level is about -50dB on the attenuator or so which provides a volume level somewhere in the 60-75dB range. The hum is equivalent to roughly -80 to -85dB playback but it is tough to tell. It is loud enough to seriously intrude on quiet passages.
I would like to modify the DC-1 to remove this, but I lack the knowledge to do so ideally myself. The hum is made up of a 60Hz tone as well as odd harmonics at greatly reduced volume, so it is certainly a ground issue. I have read from some sources e.g these two:
Basic Troubleshooting for Headphone Amplifiers
NwAvGuy: QRV09 DIY Headphone Amp
that adding resistance to the feedback loop can help resolve this. I especially trust Nwavguy since he designed the O2 which has a truly "black background," though I hate to use such subjectivist terms.
I would be okay with any modification that reduces output level since the unit already has massive headroom with my use cases anyway, but adding resistors to the output directly will unfavorably increase output impedance. I also need to locate if the hum comes from the voltage gain stage, or the output buffers. It could also come from the wire attaching to the headphone outputs, as that appears to run quite close to the large transformer.
Here is a top down view of the unit: https://emotiva.com/sites/default/fi...?itok=P0HzjYRs
Any help with this matter would be greatly appreciated.
Old 26th June 2015, 08:48 PM   #2
can you measure the output noise?
A DMM set to 199.9Vac will measure down to 0.1mVac over a restricted frequency range.
When it reads 0.0mVac, it means less than 0.05mVac
That is just about inaudible over headphones. Your level must be higher.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th June 2015, 07:59 PM   #3
Unfortunately I don't have access to a multimeter until early august - until then I would like to just gather as much information as possible.
Old 28th June 2015, 08:20 AM   #4
Post2:
missed an "m" from the voltage setting.
It should read set to 199.9mVac, allowing measurements of hum and noise down to 0.1mVac.
Hold off doing any mods until you can measure the before and after output noise.
regards Andrew T.
My turntable DC PS and Strobo Mod osscar Analogue Source 1 15th May 2014 05:56 PM
QUAD 405 (mod): DC clamp and ground schema Learnincurve Solid State 6 12th February 2014 02:01 PM
A Grounding Mod for Sequel II Rob in Montana Planars & Exotics 4 15th April 2012 11:29 PM
LM3886 kit DC grounding fabricated Chip Amps 12 13th February 2012 05:40 PM
Emotiva UMC-1 Audio board clock mod tubeing Digital Line Level 1 3rd May 2011 03:14 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
