Marantz pm57 - diyAudio
Old 25th June 2015, 08:50 AM   #1
Default Marantz pm57
Morning all,a mate has a Marantz pm57 with an intermittent left channel.
Any common faults?
Ta.
Old 25th June 2015, 01:19 PM   #2
east electronics's Avatar
poor soldering and output relay is the only problems i have seen in those amps
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 25th June 2015, 01:57 PM   #3
Thank you,very helpful,my friend does say if he turns the amp off then on again the channel works!
Old 25th June 2015, 02:16 PM   #4
correct but the best indication for a faulty relay is that :
At the time of failure if you crank the volume up then the faulty ch will play again
check both , replace relay and observe poor soldering Look carefully on the sides of the board also
Kind regards
Sakis
Old 25th June 2015, 02:36 PM   #5
Thanks Sakis,of course when I looked at the amp it worked!
I will report back when I look at the amp next time.
Kr,Barry.[aka dave Friday]
Marantz-9 thomasfw Tubes / Valves 20 6th September 2014 03:31 AM
Marantz pm57 distortion chris212 Solid State 5 23rd April 2013 01:05 PM
Right speakers for Marantz PM8000 + Marantz CD67-OSE? betto80 Multi-Way 2 24th May 2005 03:21 PM
Link Between Marantz CD12 and Marantz CD99 Mesh Digital Source 16 7th November 2003 06:08 PM
Marantz T-1 stigla Tubes / Valves 4 17th October 2002 01:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
