super simple jfet crossover with no negative freedback and unity gain.
since You need caps in Your sgnal path anyway, it´d even simpler if You go for a single supply.
I´d also prefer to add source resistors to all JFETs to prevent them becoming positive biased.
In that case it´d might be good to use differnet JFETs with a higher Idsss (2N4392 for example) that are still easy to source and cheaper.
THD should be 0.x range ... not overly but sufficiently low.
Cascoding the JFETs would seriously improve on THD-figures.
jauu
Calvin
jauu
Calvin
jauu
Calvin
Im looking for extremely simple version with least components like many purists like. Even THD is fine 0.005%
to make it simple..passive single pole high pass filter inside a pair of B1 type jFET Buffers.
- super simple Jfet crossover
