Yamaha CA-610ii
Yamaha CA-610ii
Old 17th June 2015, 12:40 PM   #1
Carlosraj is offline Carlosraj  United Kingdom
Default Yamaha CA-610ii
This amp had no sound on both channels when I received it. The protection relay was not turning ON. I opened up the amp and realised that a few resistors and 2 transistors have blown. I replaced them and turn the amp ON. There was one 1S 1555 diode blown and I replaced it with a 1N 4148. It was still the same. The relay is not turning ON. I checked the transformer and noted that the 27V AC winding has no voltage. I added a small 24V AC transformer in its place. The relay is still not turning ON and no sound. Then I tried bypassing the relay and connected the speakers to the direct output from the power transistors (prior to the relay). There is sound on both speakers and the amp seems to work as normal. I have checked all resistors, transistors and diodes on the preamp and power amp board and they all seem OK. What can be the reason for the relay not turning ON.
Carlos
Old 17th June 2015, 02:17 PM   #2
east electronics is offline east electronics  Greece
east electronics's Avatar
24 might not be enough
relay might be open
270R resistor might open under voltage
TR577--578 alike
But most of all try first with proper supply
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 17th June 2015, 03:58 PM   #3
Notice one thing more
Often there small amount of offset in the output of the amplifier enough to trigger the protection but not enough to notice when listening check that also
Yamaha of that era could have some diff semis that are busted ...
Kind regards
Sakis
Old 18th June 2015, 04:17 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
Yamaha CA-610ii
Hi Carlos,
Open capacitors in that circuit can prevent the relay from timing out and coming on. The smaller ones seem to dry out quicker. Look at your DC lines with an oscilloscope to make sure you have steady DC voltage, not pulsating DC.
The transistors can occasionally open base to emitter. This is more rare. Of course, measure the amount of DC offset you have on each output channel.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 18th June 2015, 05:17 AM   #5
frangus is offline frangus  Australia
I just fixed mine that had the same problem,
Replaced the smaller electrolytic caps on the main circuit as already suggested
Works fine now.
Old 18th June 2015, 12:31 PM   #6
Works fine now.
Thanks Guys. It was a small electrolytic cap situated near the relay. The relay is working fine now.
Carlos
Yamaha CA-610iiHide this!Advertise here!
Yamaha CA -810 Audi2014 Solid State 15 28th July 2014 09:45 PM
Yamaha CA 510 Audi2014 Solid State 1 27th February 2014 01:15 AM
Yamaha CA-610II frangus Solid State 1 17th February 2014 06:18 AM
YAMAHA CA 700 east electronics Solid State 1 10th January 2011 08:44 PM
Schems for Yamaha CA-800? Illusus Solid State 2 3rd August 2005 05:40 AM
