four transistor emitter follower (diamond buffer) as power output stage? four transistor emitter follower (diamond buffer) as power output stage? - diyAudio
Old 18th March 2002, 07:41 PM   #1
capslock is offline capslock  Europe
Question four transistor emitter follower (diamond buffer) as power output stage?
The good old four transistor unity-gain buffer which consists of a complementary emitter follower, another emitter follower pair that replaces the bias diodes and two current sources is very popular in complementary integrated op amp designs as well as some discrete designs. For a schemetic, take a look at Sonny's page:
http://www.geocities.com/sonnya5000/basicb1.jpg
He did some nice simulations about distortion and how to improve it for low impedance loads.
What I wonder about: why is this nice topology apparently not used for power output stages? Is it because it is too difficult to keep the bias constant?
Puzzled,
Eric
Old 18th March 2002, 08:03 PM   #2
HarryHaller is offline HarryHaller  United States
Banned
Default Buffer link
http://www.geocities.com/sonnya5000/basicbuffer.html
Good article. Check it out.
H.H.
Old 21st March 2002, 12:07 PM   #3
djk is offline djk
djk's Avatar
http://www.geocities.com/~ciuffoli/my/Hot_Follower1.GIF add capacitor to switch to class AB a high power http://www.geocities.com/~ciuffoli/m..._Follower1.GIF add DC servo to run without feedback http://66.34.95.145/gif/a18a.gif
--- Andrea Ciuffoli <ciuffoly@tin.it> wrote:
> Andrea Ciuffoli
> via degli Zingari 50
> 00184 Rome
> ITALY
> thank you
> dennis kleitsch wrote:
> > djk:Sorry,I don't have access to a scanner at
> work.If
> > your library doesn't have Wireless World you can
> send
> > me your postal address and I can mail you a
> > photocopy.It was in October 1976 Wireless World
> page
> > 74
> > > please, send me a san image
> > > > djk: It was published in Wireless World
> magazine
> > > many
> > > > years ago in the Circuit Ideas section.It had
> a
> > > single
> > > > transistor running class A for voltage gain as
> a
> > > front
> > > > end and had no feedback.I'll see if I can find
> and
> > > > copy it for you if you are interested.It would
> be
> > > easy
> > > > to add a DC servo to the current source
> setting
> > > > resistors.
Old 21st March 2002, 02:44 PM   #4
djk:
Thanks for posting those. I was aware of the first two, but I thought those were just paper designs, i.e. never really used and tested.
I did not know the third one. Where does it come from, what is it?
Eric
Old 22nd March 2002, 11:39 AM   #5
djk is offline djk
djk's Avatar
http://www.audio.nl/designeng.html I linked to this as I thought it was a good non-invasive way to implement a DC servo.If you examine this closely you will see that it is basically a Hafler DH-200 topology with the feedback removed, reduced B+,and biased into class A.
Old 22nd March 2002, 03:40 PM   #6
Jocko Homo is offline Jocko Homo  United States
Banned
Can't believe I missed this one.......
I've been using a version of this for years. Only I use many devices in parallel for the output followers. I get distortion numbers down near -60 dB under load.
I first saw it used in the old Audio Research D-100.......from back in the 70's. Ran hot, sounded rotten, blew up all the time.
Jocko
Old 8th March 2005, 02:51 AM   #7
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Asking the same question :
Why diamond buffer topology, like Walt Jung's never come to power amplifier output stage usage? I only see it on preamp or headphone output stage, but never in power amplifier output stage.
Why is it? Bias is not stable enough?
Old 8th March 2005, 03:27 AM   #8
wrenchone is offline wrenchone  United States
wrenchone's Avatar
I've been using a mosfet version of the diamond buffer as a power output stage for a while. I bias the first two followers with current sources and put all the devices on the same heat sink. The bias current is pretty stable.
Old 9th March 2005, 12:48 AM   #9
lumanauw's Avatar
Hi, Wrenchone,
Do you have any idea why this topology never used in commercial power amp output stage? (I never saw one)
From your experience, what is the pro/cons of using this diamond buffer topology compared with EF+VBE multiplier biasing scheme?
How much bias do you use in final stage? ClassA? low biased ClassAB?
And how is the sound?
Is this topology has a "Non-turnoff" properties (like Blomley)?
Old 9th March 2005, 01:32 AM   #10
anatech is offline anatech  Canada
anatech's Avatar
Marantz 300DC. I've been using a variation on this. Bias stability is not a problem
-Chris
four transistor emitter follower (diamond buffer) as power output stage?Hide this!Advertise here!
Do we always need an emitter follower to drive a LATFET output stage??? Leolabs Solid State 37 9th January 2011 04:16 PM
Diamond buffer + source follower Mr Evil Solid State 12 24th August 2009 11:28 PM
CFP diamond buffer output stage with vertical FETs, thermally stable? Russ White Solid State 5 1st January 2008 04:16 AM
Diamond Output buffer eats trannies (thermal) blu_line Solid State 50 13th February 2007 08:03 PM
sziklai-darlington diamond buffer (SDDB) for power output stages mtlin12 Solid State 5 1st April 2005 06:55 AM
Copyright ©1999-2017 diyAudio
