What is this amp, and what do you think of it? - diyAudio
Old 4th June 2015, 10:17 PM   #1
Default What is this amp, and what do you think of it?
Without saying too much about the make or model, can those in the know say what they think of this power amplifier? I don't know how much you can tell from a picture, but any observations relating to quality and value of the item would be interesting...
thanks
Old 4th June 2015, 10:38 PM   #2
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Taste like fish & chips.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 4th June 2015, 10:39 PM   #3
diyAudio Member RIP
Strange choice and use of that heat sink. No apparent
thermal feedback for biasing. Pretty wimpy board
tracks for the high current stuff. No attempt to use
spare board space as a ground or supply plane.
Hard to work out the rectifier arrangements.
Whatever it is I'd say its not mainstream.
Value wise I'd say nothing special, at all.
rgds, sreten.
Old 4th June 2015, 11:14 PM   #4
Those heatsinks don't look adequate.
Save the caps, xfmr, throw the rest out.
Old 4th June 2015, 11:14 PM   #5
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
power wires ditto to bottom side , there is thermal feedback on heatsink (3 blue wires)
though , info about outputs could say more ......
I think there is something interesting , but hard to say more just from pic
and - that's certainly one of wimpy UK amps
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 4th June 2015, 11:29 PM   #6
Darling-ton
(Philips 15000uF/40V, 1992, junk)
Old 5th June 2015, 12:22 AM   #7
diyAudio Member RIP
Hi, Yes I missed that looking for traces, rgds, sreten.
Old 5th June 2015, 01:04 AM   #8
ostripper's Avatar
Looks like the outputs/drivers are point to point wired direct to the PS (on the
heatsinks.
What's left on the board is apparent , LTP , servo, CCS's , VAS. Don't see the
driver pads , but do see the Vbe out on the twisted triple (3 blue's).
A shot of the other side would confirm.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 5th June 2015, 01:09 AM   #9
The heatsinks look to be substitutions since the output darlingtons are wrongly located on those extruded sections and the narrow ventilation slots don't cover them properly for cooling efficiency. Guessing they could be 72 mm high, would give a free air rating of 2.2°K/W or 2.5°K/W if 55mm high. That's not a lot of cooling when the parts are fitted incorrectly in a poorly vented enclosure.
Even though there is a reasonable sized transformer, perhaps the amplifier should only be rated about 30W/ channel?
Ian
Old 5th June 2015, 01:28 AM   #10
anatech is offline anatech  Canada
anatech's Avatar
Looks like a one-off build. For all the previous comments I would have to agree that some parts should be recycled, some shouldn't.
Either that or it's an overbuilt DIY headphone amplifier.
-Chris
"Just because you can, doesn't mean you should" © my Wife
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
Copyright ©1999-2017 diyAudio
