EV 2.0kw class H high rail oscillation? - diyAudio
Old 30th May 2015, 12:47 AM   #1
Default EV 2.0kw class H high rail oscillation?
hi guys,
im currently working on a EV 2.0kw amplifier from the 90's
its a dual switch mode power supply class H amplifier.
it had all the output fuses on the smps blown for channel B. ive successfully replaced those and i get my voltages to my output module (+/-60v & +/- 120v)
the problem is now the amp pulls way too much from the wall at idle (over 400w if i let it go) since its a switch mode supply i cant variac it or pass it thru the light bulb limiter so i switch it off as soon as i see it pass the 300w range.
my troubleshooting has gone so far: (channel B)
-if i disconnect +/-60v & +/-120v from psu B to output module B, amp does not pull more then 100w from wall at idle.(no signal output)
-if i disconnect only +/- 120v rail from psu B to output module B amp does not pull more then 100w at idle ( does pass audio without distortion until maxed out rail)
- if i disconnect only +120v rail from psu B to output module B, amp does not pull more then 100w at idle (audio passes, maxes out rail, does not engage - high rail)
-when i reconnect +120v rail from psu B to output module B amp DOES pull over 400w from the wall ( no audio passes)
-when +/-120v is disconnected audio passes cleanly , output transistors get warm at low volume.
-when +/-120v rail disconnected, looking at the bias voltage of the output transistors with a scope, there is a 41khz noise signal reaching maybe 1v
-when both rails plugged in, the signal before the speaker protection relay on a scope jumps positive(rail voltage) then quickly negative and quickly to 0v with some noise on it,
i now suspect an oscillation on that channel, but ive never dealt with oscillation before, so im not sure.
could anyone point me something out that im missing?
its oscilating but with the high rail out it still plays?
the schematics can be found on the complete last page of the user manual >here<
thank you for your help!
Allison Biased Class A Amplifier with Rail to Rail output and acceptable Class AB GregH2 Solid State 5 18th November 2014 02:58 AM
Cheap high voltage high wattage dual rail SMPS devices minimelkav Power Supplies 2 22nd August 2014 03:35 PM
Newly built ESP P03 (not 3A) - rail to rail oscillation - suggestions? tbj Solid State 2 29th October 2012 02:44 PM
EV SP12C with too-low output and too-high coil DCR... jon_010101 Multi-Way 2 21st June 2009 09:31 PM
ad8610 class a bias +v rail or-v rail? crippledchicken Solid State 11 29th April 2004 07:35 AM
Copyright 1999-2017 diyAudio
