Power at 8ohm, 4 and 2....
Old 26th May 2015, 06:40 AM   #1
zenpmd is offline zenpmd
Default Power at 8ohm, 4 and 2....
Can anyone explain to me why it is a good thing to have amp A over amp B?
Amp A
8ohm -200w
4ohm - 400w
Amp B
8ohm - 200w
4ohm - 320w
In other words the wattage doubling down as ohms do?
Thanks!
Old 26th May 2015, 07:11 AM   #2
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Amp A looks to have a regulated supply - so its power supply's not sagging under heavier load. A stiffer power supply is generally regarded as a good thing to have.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 26th May 2015, 08:27 AM   #3
DF96 is offline DF96  England
If the figures are for sustained sine wave drive, then it may be that on occasional musical peaks that amp B (with an unregulated supply) can go to higher power than amp A. It all depends on whether you want to listen to real music or manufactured music with no dynamic range. The bare power figures don't give enough information on their own for someone to make an informed choice.
Old 26th May 2015, 12:52 PM   #4
east electronics is offline east electronics  Greece
east electronics's Avatar
well .... not so many amplifiers i ve seen in the Cheap pro area with regulated power supply so i don't think that this is the issue here ...
Since we don't know the models and so on the all thing is hypothetical ...
In reality though you can have double the Watt in 4 ohm load given :
--- that power supply will manage
---Number of outputs will manage both current and thermals
---VI limiter will allow that
In cheap pro amps this will never happen or it may happen on resistive tests , In reality and with a speaker as a load VI limiter will not allow that much power like double the wattage in Ohm
To the OP i could trust more the second amplifier since its spec looks like a number that has been measured not calculated ...Probably the limiter doesn't allow double the Wattage on 4 Ohm due to the above limitations ..
Kind regards
Sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 26th May 2015, 02:17 PM   #5
Chamberman is offline Chamberman  United States
Amp A
8ohm -200w
4ohm - 400w
Amp B
8ohm - 200w
4ohm - 320w
Thanks!
In answer to your actual question. If both amps are being measured in the same manner then amplifier A will have better output power into lower impedance.
Due to the fact they are likely not being measured in the same manner there are other things you can look at. Do either of the amplifiers give a 2ohm rating? Are the measurements with "both channels driven" this is a much better indicator of the power supply size? What are the THD numbers at the rated power outputs?
KC
Old 26th May 2015, 02:28 PM   #6
If they tell the truth ...which in most cases they don't .....also measured ??? i don't think so ...i think this is coming only form the specs so amp B probably says the truth ...
Old 26th May 2015, 02:40 PM   #7
wwenze is offline wwenze  Singapore
Just a design decision... of how much current and voltage the parts can output.
I pick whichever gives me better performance at 1W. The difference between 1W and 10W is just 10dB. Same goes for 10W vs 100W. 320W vs 400W is negligible in terms of SPL.
Add: Overall, amp A has more capacity, because if we assume that both amps are limited by voltage at 8 ohm, then at 4 ohm, amp A is still limited by voltage but amp B is limited by current. If you go further down to 2 ohm, you may squeeze even more power out of amp A, but most likely you'll get less power from amp B.
Just as it is good to have additional current capacity, having additional voltage capacity is also good for sound. However both amps have the same max output voltage (since power into 8 ohm is the same) so I grab the one with more current capacity.
This is before we consider another limiting factor of power, which is heat (or cooling). Some amps have a 8ohm/4ohm switch that reduces supply voltage when 4ohm is selected.
Old 26th May 2015, 02:42 PM   #8
wg_ski is offline wg_ski  United States
More meaningful would be to find out 1) what is the rail voltage? 2)what is the VA capability of the transformer? 3) how much capacitance? and 4) how many output transistors in parallel?. The answers to those qustions will see right through the lies. Back in the day, we used to judge amplifiers by weight.
Old 26th May 2015, 02:45 PM   #9
In a production amplifier its a cost issue. Massive power supplies and extra output transistors are expensive.
KC
Old 27th May 2015, 05:48 AM   #10
djk is offline djk
R.I.P
djk's Avatar
"Amp A looks to have a regulated supply "
Uhh...amp A is understating its 8Ω power.
Which sounds better?
A listening test is in order here.
Candidates for the Darwin Award should not read this author.
Power at 8ohm, 4 and 2....Hide this!Advertise here!
Can my vintage receiver power dual 8ohm subs? stampants Subwoofers 8 19th November 2014 07:30 PM
63watt class A into 8Ohm, 110watt semi-class A into 8Ohm, @ 20Khz 3rd harmonic -90dB FdW Solid State 47 31st December 2010 04:05 PM
8ohm resistor in series with 8ohm speakers for a 16ohm OT? Reidy- Tubes / Valves 8 10th January 2010 11:25 PM
Kenwood KM-207 - 200 Watts x 2/8ohm - power amplifier - $100 + shipping zobsky Swap Meet 0 29th March 2009 10:00 PM
8ohm Eros bhg41088 Multi-Way 0 9th April 2004 02:49 AM
