Add more inputs to vintage preamp? - diyAudio
Old 18th May 2015, 08:26 PM   #1
ChopperCharles's Avatar
Default Add more inputs to vintage preamp?
Has anyone ever replaced the input selector rotary switch on a preamp with a switch that has more positions? I have a Toshiba SY-300 Mk. II preamp, and it only has Tuner/Phono/Aux 3-position rotary switch. I'd like to swap in a 5-position switch, as well as add a switch to defeat the RIAA circuit, as I have a vacuum tube phono stage I'd rather use on that input.
I found a 2-pole 5-position rotary switch on eBay for $8.50 shipped, which is sealed and has a split shaft like the Toshiba amp. Hoping it can be an easy drop-in.
Thoughts?
Charles.
Old 19th May 2015, 12:50 AM   #2
Don't do it. Get this: Black 3 Way Port Audio Video AV RCA Switch Selector Box Splitter & 3 RCA Cable Sale-Banggood.com. Yes it is ugly, but easy. E
Old 19th May 2015, 01:28 AM   #3
rayma is offline rayma  United States
Originally Posted by mickeymoose View Post
Don't do it.
Or you can build your own better quality selector in a box and run the output into the tape monitor input,
bypassing the internal selector switch.
Old 20th May 2015, 12:16 AM   #4
I already built my own selector box for another system, which is why I'm thinking of tackling this. It didn't seem so hard, so why not do it again, inside an inexpensive but decent preamp? (I spent $35 for the preamp off that great yard sale in the cloud (eBay)).
Passive preamp, multiple inputs? neazoi Digital Line Level 4 14th October 2009 07:42 AM
ground bus for inputs on preamp - what's best? cbutterworth Tubes / Valves 9 28th August 2009 04:34 AM
Convert Or Add XLR Inputs To Power Amp? DaveThreshold Solid State 19 29th May 2009 01:41 AM
Phantom Power through my vintage xformer inputs northsiderap Analogue Source 6 4th May 2005 08:16 PM
Adding more inputs for my preamp bonsai171 Solid State 1 11th March 2004 10:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
