Hi
I am working on the above amp and realised that the power IC, STK043 has blown up. This IC is totally obsolete. I compared the data for this IC with STK460, both are rated 20W, 32V. Can I replace this IC with STK460 or STK465. Please assist
Carlos
I live in a country far away from civilization. Therefore it was necessary to repair the hybrid chip. Explodes only output transistor. You can open the enclosure and replace it externally. So I repaired during the USSR.
