Transformer Upgrade - diyAudio
Old 4th May 2015, 02:57 PM   #1
Default Transformer Upgrade
I want to install a more powerful transformer on my preamp. I was looking at the following transformer AN-2225 - 200VA 25V Transformer - AnTek Products Corp which the designer recommends. Unfortunately they do not have it in stock. I sourced out two Hammond transformers and trying to pick one of them which comes close to mirroring the same specs as the Antek. The Hammond transformers are: http://www.hammondmfg.com/pdf2/1182P12.pdf and http://www.hammondmfg.com/pdf2/1182P22.pdf. Which one comes closest to the Antek? Thanks
Less is more in High-End Audio, but not too less.
Old 4th May 2015, 03:08 PM   #2
That transformer has a maximum continuous output of around 2.5Adc and when downrated for cool running duty can still manage 1250mAdc continuously.
That would supply a pair of pre-amps for a long time !
regards Andrew T.
Old 5th May 2015, 12:22 PM   #3
The preamp has a non-toroid transformer. This upgrade is approved by the designer and has been done by other people with great success. I want to know which one of the two Hammonds come closest to the Antek.
Old 5th May 2015, 01:53 PM   #4
Obviously the second one is the only one that's anywhere near close, as the first is only 12V, and the second is 22V - the Antek is 25V.
However, has this 'great success' been proved by measurements or double-blind tests - I wouldn't expect a preamp to be improved by a 200W mains transformer, and a toroid should make no difference either.
Nigel Goodwin
Old 5th May 2015, 02:57 PM   #5
I appreciate your response Nigel. I believe the first Hammond is feasible if the secondaries are connected in series giving 24volts(only 1 volt difference) and the amps will remain the same at about 5 amps. Is this correct?
Old 6th May 2015, 07:30 AM   #6
I don't think so.
The amps will not remain at 5Aac.
They might vary between 0mAac to 200mAac.
regards Andrew T.
Old 6th May 2015, 08:29 AM   #7
AJT is offline AJT  Philippines
AJT's Avatar
whoa, big big traffos for a preamp?
how much power does your preamp consume anyway?
or maybe you mean power amp perhaps?
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 6th May 2015, 08:36 AM   #8
AJT's Avatar
try not to lose sleep over a 1volt difference...
variations in your line/loads will make that a non issue...
Old 6th May 2015, 09:54 AM   #9
Except you then only have a single supply (0-24V - from a 12V-0-12V transformer), the original is 25V-0-25V presumably because the preamp uses a split supply?.
But again, why the huge wattage transformer?, is it a power amp as well as a preamp?.
Nigel Goodwin
Old 6th May 2015, 10:34 PM   #10
It is my understanding that the larger the transformer ,within limits, assuming the audio board is capable of handling the extra voltage the better the sound.
It is a dual mono preamp with phono stage.
Edcor transformer upgrade for K12G tube amp? bmanh Tubes / Valves 10 12th November 2014 09:41 AM
Upgrade the transformer domolo Power Supplies 5 15th December 2012 12:05 PM
upgrade transformer? ipop07 Tubes / Valves 6 22nd August 2008 06:53 PM
MTX amp unregulated, transformer upgrade? gxenakis Car Audio 7 29th April 2007 03:34 PM
BOZ upgrade: wich transformer ? Gubby Pass Labs 3 17th May 2004 11:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
