Just won a AB International 600LX, what to check first? - diyAudio
Old 29th April 2015, 10:01 PM   #1
xxllmm4 is offline xxllmm4  United States
Default Just won a AB International 600LX, what to check first?
Hey everyone,
On the advice given here I just won an AB International Precedent Series 600LX AB International Precedent Series 600LX 2 Channel Amplifier | eBay my question how do I check this amp out before I hook it up? I have a decent multimeter.
Jordon
Old 29th April 2015, 10:09 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Seems straightforward enough.
Power it up with nothing connected. If it shows signs of life, plug in one loudspeaker at a time in. If all OK, switch off and insert a signal input. Power up again and if it works, bonus. that's is about it.
Unless you believe it to be faulty!
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 30th April 2015, 12:57 AM   #3
Thanks, I thought you needed to test these old PA amps first before hooking speakers up. Good news
Old 30th April 2015, 03:24 AM   #4
ostripper's Avatar
You could get the schematic , check offset /bias.
AB 600 series has 3 similar "leach amp" type circuits. Older 600
has no servo (below - the "a").
LX might be a round toroid and a servo - same amp with 3 pair
BJT TO-3 outputs.
OS
Mongrel website , always current and updated :
http://www.fidelityforce.com/ostripper
Old 30th April 2015, 07:37 AM   #5
djk is offline djk
djk's Avatar
So you're the one that out bid me (by $1)!
Power it up and check there is no DC on the speaker outs (before hooking up speakers).
Use the 1/4" inputs, not the balanced (unless you work on them).
Clean the input jacks and front panel pots.
Candidates for the Darwin Award should not read this author.
Old 30th April 2015, 05:03 PM   #6
Sorry, I was hoping it wasn't someone form here LOL
Thanks for the advice. I'm sure i'll have lots more questions once I get it. I have always been involved in the speaker building side of the hobby, not the amp tinkering.
Old 30th April 2015, 10:14 PM   #7
djk is offline djk
djk's Avatar
"Sorry, I was hoping it wasn't someone form here LOL"
I have so many 400 and 600 now I can't remember the exact numbers.
Old 1st May 2015, 02:02 AM   #8
Hey djk, I guess you would be the one to ask then. I'm running a set of Cerwin Vega 6 ohm speakers. The plan is to get another identical set and run them all off the same amp. How would this amp be running a 3 ohm load? I have heard 2 ohm is iffy.
Old 1st May 2015, 06:19 AM   #9
djk is offline djk
djk's Avatar
If you measure those 6Ω Cerwin Vega, I'll wager that the DCR will be under 4Ω, so two will be a problem.
You could buy a different transformer, a 40-0-40V 800VA~1KVA unit would allow the AB 600 to drive 2Ω safely. It might be cheaper to pick up another amp.
AB international precedent 1450 rail voltage? ief Solid State 14 7th January 2015 03:59 PM
AB international 9620b channel gone BigE Solid State 0 17th November 2014 02:48 AM
AB International 400 Power Amplifier Repair WSJ Instruments and Amps 1 6th June 2013 03:16 AM
Ab International 322t SS64 Solid State 0 21st June 2011 12:53 AM
AB international 9620 amp with blown channel xplod1236 Solid State 73 13th September 2008 05:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
