best Value in used high power amps? - diyAudio
Old 24th April 2015, 05:55 PM   #1
xxllmm4 is offline xxllmm4  United States
Default best Value in used high power amps?
Hey everyone,
So I'm on the lookout for a decent used high powered amp for my garage stereo. I'm looking for at least 150 WPC RMS @ 8 ohms. I would love to get a Carver or Adcom but they are all out of my price league. So its most likely going to be a main stream amp from the late 80's - early 90's.
I need to get a good deal on it, Craigslist or Goodwill. So what would you reccomend looking for. It takes a lot of time sifting through all the Craigslist posts. It seems like all you can find at Goodwill is surround sound stuff.
Jordon
Old 25th April 2015, 08:02 AM   #2
Brisso57's Avatar
Hafler?
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 25th April 2015, 08:52 AM   #3
djk is offline djk
djk's Avatar
AB International Precedent Series 600LX 2 Channel Amplifier | eBay
AB International 600LX or 400, avoid the 900.
AB made the Cinepro amplifiers, just a different face plate.
Candidates for the Darwin Award should not read this author.
Old 25th April 2015, 11:06 AM   #4
indianajo's Avatar
I would say 150 w/ch is medium power. I picked up a blown Peavey PV-1.3k @ 360 w/ch for $55 on craigslist, then put $80 in parts in it. The PV-8c would do for you, or the PV-4 is 120 w/ch 8 ohms. These come apart very easily and unique parts like long life fans are still available from peavey. The fan runs slow at low power and is not a nuisance.
The year I spent learning how to fix the thing was not exactly free, but was a great education.
Your bargains will be transformer driven amps like those three or the CS800x or previous. the CS800x series has better speaker protection than the PV series. The CS800s and later has a switcher power supply, which is lighter but requires more skill to repair.
If you're feeling frisky, the honey badger kit from diyaudio supply is a bargain and comes with a free educational pdf file on amp design features. You could put one in a steel porta-file box or something, with a little fan. Or you could salvage a VFD motor drive enclosure with the heatsinks already installed on the back, like the semi units out of a Heat & Control fastback conveyor. These have stainless boxes with a 3 phase switch on the front.
Oh, and ditch the 1/4 phone plugs. If the dog pulls one out slightly, it shorts and blows the amp. The band that sold the PV-1.3k to me had gone to dual banana plugs on the amp end. Unfortunately good old speakers still use 1/4 phone plugs.
BTW for quickest craiglist search, try searchtempest.com Has a geographic limit of how far you want to drive, very convenient. Hits all the categories at the same time, too. Also, now that craiglist forces the picture on you of every guitar and native flute, searchtemptest leaves the pictures out for faster scanning.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 25th April 2015, 11:15 AM   #5
ghg is offline ghg  Austria
ghg's Avatar
Any DENON POA-xxxx
like POA-2200 POA-2400 POA-2800 etc.
I hate "sounding amps", except these are Marshalls, driven by Eric C. or Jeff B., period.
Old 25th April 2015, 12:42 PM   #6
sregor is offline sregor  United States
Crown XLS 202 or 402.
Steve
Old 25th April 2015, 01:29 PM   #7
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
crown ce1000 or ce2000 can often be had for a good price.
http://www.evancotler.com
Old 25th April 2015, 02:53 PM   #8
Welcome's Avatar
Old Yamaha PA amps tend to go for very little money, but are quite good - even for home use / hi-fi.
Old 26th April 2015, 03:31 AM   #9
Thanks for all the input, keep em coming if you can think of anything else
Old 26th April 2015, 06:23 AM   #10
djk is offline djk
djk's Avatar
The Crowns mentioned all use fans.
If you don't mind the fan a Crown CH1 is the contractor version of the CE amplifier series.
At 275W/8Ω per channel it should be big enough for you. I mention this series as they sell for $50~$100 less than the CE series.
The AB International have a design that is virtually identical to the Leach amplifiers, a well respected hi-fi design. A super clean AB 600 went for less than $110 (shipped) last week. If I didn't own a dozen AB amplifiers I would have bid on this one.
AB International Precedent Series 600A | eBay
Advantages of Power Cords with braided Shield for high Power Solid State Power Amps tiefbassuebertr Solid State 39 12th February 2015 04:32 PM
Several large Toroidal Transformers for high power amps K-amps Swap Meet 1 26th May 2013 10:30 AM
A/B testing board for high power amps udailey Class D 6 1st October 2011 08:59 PM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
