Recapping a Quad 303 - diyAudio
Old 24th April 2015, 07:44 AM   #1
Brisso57's Avatar
Default Recapping a Quad 303
Hi
Has anyone used these caps from Apex Jr to recap their Quad 303's filter caps?
http://apexjr.com/images/4700uFChemecon.JPG
If so, would you recommend them?
cheers
Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all."
Old 24th April 2015, 04:29 PM   #2
Welcome's Avatar
Date code suggests they might be from 2004 or 2007, so I wouldn't recommend them. Get something more recent, 2013 at the earliest.
Old 24th April 2015, 06:43 PM   #3
poynton is offline poynton  United Kingdom
poynton's Avatar
The filter caps should be 100v since the rectified voltage is 94v.
80v caps would be in danger of failing.
The output caps can be 63v.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 24th April 2015, 08:34 PM   #4
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
These fit a treat;
B41456B9478M. - EPCOS - CAP, ALU ELEC, 4700UF, 100V, SCREW | Farnell element14
Support for Flying Mole, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 25th April 2015, 04:24 AM   #5
This is what you'd pay in Brisbane, which seems fair price parity. You can see these are quality, long-life capacitors, not the 2,000 hour junk grade but they aren't stocked here and the price includes airfreight from UK. Local delivery should be free to a/c customers. If it fits "a treat", that saves a bit of sweat making adaptor collars too. All you need then is a dozen ring terminals to suit the 5mm screws.
B41456B9478M. - EPCOS - CAP, ALU ELEC, 4700UF, 100V, SCREW | element14 Australia
Ian
QUAD 303 GEEK24 Solid State 0 12th June 2014 12:46 PM
Quad 303 recap Piccolino Solid State 4 30th May 2014 09:50 AM
quad 303 lpccorreia Solid State 1 10th March 2014 12:13 PM
Quad 303 Upgrade - How far is too far? HiFiWill Solid State 13 28th March 2013 02:19 PM
Quad 303 problem Intheloft Solid State 2 17th April 2010 01:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
