what do you think of this design? - diyAudio
Old Yesterday, 06:14 PM   #1
wertz is offline wertz  Philippines
Default what do you think of this design?
hi. please evaluate this amp design. this is a schematic i made from my amp, in an attempt to understand why offset on left channel is 10mV while the other one is 0mV. anyways assuming i made no error in making the schematic, is this a good design? also i can't seem understand also why T7 is wired like that?
what is possible replacement for C4468/A1695 just incase this thing breaks...
Old Yesterday, 06:29 PM   #2
Mooly's Avatar
Erm
There are quite a few errors in the diagram for it to even get close to working. T4 is drawn incorrectly wired (B-E should be across R6), the bias generator is all 'upside down' and one of the 2N5551's (can't make the ref number out) is incorrect. T13 is a 2SA (just a typo).
T7, I have seen that kind of configuration before... it is odd. Offset at 10mv sounds absolutely fine for this and variations are normal and down to simple (unavoidable) mismatching around the input stage. It is of no consequence.
Installing and using LTspice. From beginner to advanced.
Old Yesterday, 06:35 PM   #3
rayma is offline rayma  United States
It's connected as a cascode. Also, 10mV is a small (and normal) amount of offset.
Old Yesterday, 07:46 PM   #4
jerluwoo's Avatar
T4,T8 and T9 collector and emitter are reversed. The ltp ccs will only generate ~15uA, R6 is probably incorrect value. No idea what R3 is for. R12, C9 on the wrong side of R10. C11 polarity reversed.
Sound Design, a new book on innovative and interesting ideas in speaker design. Studio Au Multi-Way 3 8th April 2012 08:46 PM
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Metronome style design for multiple drivers, a number of design questions mountainhick Multi-Way 5 28th January 2010 03:31 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
