SAE 310 Transistor replacement info - diyAudio
Old 20th April 2015, 03:31 PM   #1
dallek1 is offline dallek1  United States
Default SAE 310 Transistor replacement info
hello,
I have an SAE 310, I need to replace the transistor, (power/TO-3) . they are impossible to read the original numbers, they were stamped SAE1 and SAE2. can anyone provide the correct part numbers please?
ns
Old 21st April 2015, 08:28 AM   #2
djk is offline djk
djk's Avatar
SAE 310, or 3100?
The 100W 3100 needs high voltage parts, the 50W 310 uses darlinton.
I would probably use MJ21195/96 for the 3100 (also suggested by Bongiorno, the designer), or MJ11021/22 for the 310.
http://www.onsemi.com/pub_link/Collateral/MJ11021-D.PDF
The original darlington are NLA, and were rated much lower.
On second thought, these are the same spec as the original (2N6052/59)
http://www.mouser.com/ds/2/68/2n6050-6052-17130.pdf
Candidates for the Darwin Award should not read this author.
Old 21st April 2015, 01:57 PM   #3
Originally Posted by djk View Post
SAE 310, or 3100?
i could not ask for a better reply, I found a cross reference site in the meantime but your reply is better, way better.
thank you
ns
Old 27th April 2015, 07:35 PM   #4
please can you tell be the bias procedure for this amp, I should be reading across the 0.2 ohm 5 watt resistors right but what am I setting it to? please?
ns
SAE 11-0068 and SAE 11-0074 Transistors - info need Zeljko Parts 0 29th March 2015 07:15 AM
NAD 310 - need some info Filip_84 Solid State 13 2nd April 2010 02:16 PM
SAE MK IIIB transistor sub. ostie01 Solid State 0 10th June 2006 08:08 PM
Need Info/Datasheet/possible Replacement on H1061 transistor JhonDoe Parts 1 5th March 2006 02:29 AM
Anyone know of a drop in replacement for the PE 279-310? JZatopa Multi-Way 0 4th September 2003 11:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
